Date/Time: Wed, 12 Feb 2025 00:43:01 +0000
Problems with orders fills
View Count: 785
[2020-09-25 09:54:53] |
Chap - Posts: 39 |
Hi, in the attached imagine, you can see the fills colors and connections lines are wrong for the current trade (trade evaluator), im noticing this in many trades. connect fills with older trades, and colors are wrong. Thanks for your help |
[2020-09-25 19:49:27] |
Refer to this section here in regards to this: Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities Make sure the Order Fills Start Date-Time setting is set correctly. Would be best to set those to 0: Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu) And enable this: Chart Settings: Filter Initial Fills Which Are Part of Existing Position (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-25 19:50:06
[2020-09-26 12:17:16] |
Chap - Posts: 39 |
Hi, I checked everything, and I could not solve the problem. in this 3 contracts trade, the color fill of the exit of the last 2 contracts are wrong and there is not connection line. Please your help. |
![]() Attachment Deleted. |
