Date/Time: Tue, 11 Feb 2025 21:10:25 +0000
Upgrading to Pkg 5 while using Amp
View Count: 687
[2020-09-24 23:38:25]
UserNSNInvest - Posts: 1
Hi -
I recently started using SC (Pkg 3) through my Amp Futures account. I LOVE Sierra Chart! I love that I can customize it exactly like I want. I love that it doesn't get itself tangled up in the Windows Registry or require me to install 20 year old MS C++ distributions. I love that it's 64-bit (currently running on a Ryzen 9 3900x with 32gb RAM). I'm enjoying SC so much that I would like to subscribe to the Pkg 5 level, independent of my Amp account, so that I can pay Sierra directly and support the cause.
However, I have 2 questions about doing this that I hope you can answer for me:
1) I am subscribed to CQG feed and CME/CBOT market depth data via my Amp subscription. I don't exactly understand the linkage between Amp, SC, and CQG that well, but I am thinking that I will need to keep my CQG and Amp accounts as is in order to continue to trade with Amp. However... I would also like to take advantage of the SC data feeds for equities research and charting. Is it possible to have 2 feeds populating symbols/prices in a single SC instance? Or, maybe I should ask... can I do this and if so how?
For example, I currently log in using my Amp account #, and get CQG using the credentials provided via Amp for the CQG feed. How would I log in and still use Amp to trade if I had a separate, personal subscription to SC?
2) I have an existing pre-paid Pkg 3 sub now under my personal account, that I would want to upgrade to Pkg 5. I imagine that's pretty easy, but how would I do that?
Thank you for your help!
Date Time Of Last Edit: 2020-09-24 23:43:53
[2020-09-25 05:16:22]
Yes. Refer to:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
For US equities you will want to use this data feed:
Sierra Chart Exchange Data Feed
You just log into Sierra Chart with your own direct account:
Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name
Instructions:
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
