Date/Time: Wed, 12 Feb 2025 10:50:53 +0000
custom symbols ROUND TURN COMMISSIONS not showing up?
View Count: 605
[2020-09-24 18:56:24]
User220914 - Posts: 239
HI
I am working on demo trading of custom contracts with your dom capability for custom contracts.
When i build the custom symbol i use the commission plus what i deem to be my slippage so lets say
this round turn slippage plus fees is 7 dollars.
If i use this 7 dollars in my custom symbols as the round turn commission it is not
showing up in the dom as a runnign P and L and it also is not showing up in the trade statistics.
I have checked use commisson.fees in the chart settings and in the trade statistics settings.
I can get my trades to mark up on the charts as far as entry and exit so i know the system is seeing them
and offsetting them properly,
thank you
[2020-09-25 19:33:15]
We will test this.
[2020-10-25 23:29:51]
We identified the issue. You also need to set the Currency Value per Tick in the Global Symbol Settings.
This is the documentation for it in Chart Settings which you can set alternatively:
Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
