Date/Time: Wed, 12 Feb 2025 01:45:50 +0000
Message log constantly showing
View Count: 728
[2020-09-24 08:58:37] |
User93464 - Posts: 52 |
Dear support, My message log is showing the following message every second, repeatedly "Data file is currently being processed. Download not performed. | 2020-09-24 09:54:22.086 *" Please advise on how I identify the problem Data File. Regards |
[2020-09-24 22:18:59] |
Not sure why the file is being processed by another task. This is unusual. May be due to intraday data file management which you would have had to manually start, there could be some other items as well. The easiest thing to do is to restart Sierra Chart to solve the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-24 22:19:05
[2020-09-25 05:16:01] |
I have restarted Sierra Charts many times and the issue continues to appear. Please advise me on how to identify the problem data file |
[2020-09-25 19:00:12] |
After restarting Sierra Chart and as soon as you see that message we need you to provide the Message Log by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog If we do not see the relevant message, we will need to add more logging. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-25 22:02:15] |
Message log sent under support log 89930 Reading Internal Order ID file. | 2020-09-25 22:56:54.077 Reading Trade Orders file. | 2020-09-25 22:56:54.158 Reading Trade Positions file. | 2020-09-25 22:56:54.158 Reading Account Balance file. | 2020-09-25 22:56:54.159 UDPListener (1360). Port 22903 | Listening on UDP port 22903. | 2020-09-25 22:56:54.175 Software version: 2168 64-bit | 2020-09-25 22:56:54.175 Primary Thread ID: 11916 | 2020-09-25 22:56:54.175 Usage end date: 2020-10-11 | 2020-09-25 22:56:54.175 Enabled for: Advanced Features 2. | 2020-09-25 22:56:54.175 Enabled for: Sierra Chart Historical Data Service. | 2020-09-25 22:56:54.175 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-09-25 22:56:54.175 Allow Support for Sierra Chart Data Feeds is disabled. | 2020-09-25 22:56:54.175 Current selected Data/Trading service: SC Data - All Services | 2020-09-25 22:56:54.175 Custom symbol settings values: enabled | 2020-09-25 22:56:54.175 Chart Update Interval: 300 | 2020-09-25 22:56:54.175 Intraday Data Storage Time Unit: 0 | 2020-09-25 22:56:54.175 Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2020-09-25 22:56:54.175 2020-09-25 22:56:54 Local computer time | 2020-09-25 22:56:54.175 2020-09-25 21:56:54 Local computer time in UTC | 2020-09-25 22:56:54.175 2020-09-25 22:56:54 Local computer time in SC Time Zone | 2020-09-25 22:56:54.175 2020-09-25 21:56:53 Server time in UTC | 2020-09-25 22:56:54.175 Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-09-25 22:56:54.175 Program path: C:\SierraChart\ | 2020-09-25 22:56:54.175 Data Files path: C:\SierraChart\Data\ | 2020-09-25 22:56:54.175 OS Version Number: 10.0 | 2020-09-25 22:56:54.176 Locale Setting: C | 2020-09-25 22:56:54.176 DLLs: BetterMomentum1_1_64.dll, BetterMomentum2.dll, BetterMomentum2_1_64.dll, Compass Institutional - Levels.dll, DBsync7B_2158_64.dll, DBsync7B_64.dll, DBsync7C_2158_64.dll, DBsync7C_64.dll, ECIDeltaV0.5.dll, Formula.dll, JOFA.dll, PRC1_2158_64.dll, PRC1_64.dll, sst_YieldStudy.dll, Trade29CustomStudies.dll, Trade29CustomStudies_2151_64.dll, Trade29CustomStudies_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll, Ysync7B2_2158_64.dll, Ysync7B2_64.dll, Ysync7C2_2158_64.dll, Ysync7C2_64.dll | 2020-09-25 22:56:54.176 Allowed protected custom studies: DT_MarketMaker, Trade29 Custom Studies | 2020-09-25 22:56:54.176 Created the DTC Protocol server. | 2020-09-25 22:56:54.198 DTC Protocol Server listening on port 11099. | 2020-09-25 22:56:54.199 Created the DTC Protocol historical data server. | 2020-09-25 22:56:54.199 HD Server Manager | Listening on port 11098 | 2020-09-25 22:56:54.200 Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2020-09-25 22:56:54.200 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-09-25 22:56:54.241 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-09-25 22:56:54.269 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-09-25 22:56:54.269 Received 5 login tokens. | 2020-09-25 22:56:54.301 Symbol settings MD5 received. Request ID: 1. | 2020-09-25 22:56:56.991 Requested symbol settings for service code scdataallservices. Request ID: 2. | 2020-09-25 22:56:56.991 Files to Open on Start up | Opening file: DB yields.Cht | 2020-09-25 22:56:57.373 Loading DLL C:\SierraChart\Data\Ysync7C2_2158_64.dll | 2020-09-25 22:56:57.377 EURUSD 1 Min #1 | Reloading chart. | 2020-09-25 22:56:57.386 Files to Open on Start up | Opening file: SEAN GB Sam.Cht | 2020-09-25 22:56:57.391 GBPUSD 15 Min #1 | Reloading chart. | 2020-09-25 22:56:57.405 US02YY1 1 Min #2 | Reloading chart. | 2020-09-25 22:56:57.412 US10YY1 1 Min #3 | Reloading chart. | 2020-09-25 22:56:57.419 GB02YY1 1 Min #4 | Reloading chart. | 2020-09-25 22:56:57.432 GB10YY1 1 Min #5 | Reloading chart. | 2020-09-25 22:56:57.448 GBPUSD 30 Min #6 | Reloading chart. | 2020-09-25 22:56:57.464 Loading DLL C:\SierraChart\Data\UserContributedStudies_64.dll | 2020-09-25 22:56:57.471 Loading DLL C:\SierraChart\Data\BetterMomentum2_1_64.dll | 2020-09-25 22:56:57.487 The advanced custom study C:\SierraChart\Data\BetterMomentum2_1.dll needs to be recompiled to be used on this version: 2168 | 2020-09-25 22:56:57.489 * GBPUSD 5 Min #7 | Reloading chart. | 2020-09-25 22:56:57.499 GBPUSD 1 Min #8 | Reloading chart. | 2020-09-25 22:56:57.522 SPX500 5 Min #9 | Reloading chart. | 2020-09-25 22:56:57.534 UK100 5 Min #10 | Reloading chart. | 2020-09-25 22:56:57.547 USDX 1 Min #11 | Reloading chart. | 2020-09-25 22:56:57.562 USDJPY 1 Min #12 | Reloading chart. | 2020-09-25 22:56:57.573 EURUSD 1 Min #14 | Reloading chart. | 2020-09-25 22:56:57.611 SPX500 1 Min #13 | Reloading chart. | 2020-09-25 22:56:57.622 Files to Open on Start up | Opening file: SEAN EU Sam.Cht | 2020-09-25 22:56:57.632 EURUSD 15 Min #1 | Reloading chart. | 2020-09-25 22:56:58.077 US02YY1 1 Min #2 | Reloading chart. | 2020-09-25 22:56:58.086 US10YY1 1 Min #3 | Reloading chart. | 2020-09-25 22:56:58.097 DE02YY1 1 Min #4 | Reloading chart. | 2020-09-25 22:56:58.349 DE10YY1 1 Min #5 | Reloading chart. | 2020-09-25 22:56:58.541 EURUSD 60 Min #6 | Reloading chart. | 2020-09-25 22:56:58.556 EURUSD 5 Min #7 | Reloading chart. | 2020-09-25 22:56:58.645 EURUSD 1 Min #8 | Reloading chart. | 2020-09-25 22:56:58.673 SPX500 1 Min #9 | Reloading chart. | 2020-09-25 22:56:58.688 GER30 1 Min #10 | Reloading chart. | 2020-09-25 22:56:58.698 USDJPY 1 Min #12 | Reloading chart. | 2020-09-25 22:56:58.714 EURJPY 1 Min #13 | Reloading chart. | 2020-09-25 22:56:58.726 {DE10YY1}-{US10YY1} 5 Min #14 | Reloading chart. | 2020-09-25 22:57:00.848 EURJPY 1 Min #17 | Reloading chart. | 2020-09-25 22:57:00.860 USD-X 1 Min #11 | Reloading chart. | 2020-09-25 22:57:00.873 USDJPY 1 Min #15 | Reloading chart. | 2020-09-25 22:57:00.886 Files to Open on Start up | Opening file: SEAN EJ Sam.Cht | 2020-09-25 22:57:00.895 EURJPY 15 Min #1 | Reloading chart. | 2020-09-25 22:57:01.366 JP02YY1 1 Min #2 | Reloading chart. | 2020-09-25 22:57:02.828 JP10YY1 1 Min #3 | Reloading chart. | 2020-09-25 22:57:03.850 DE02YY1 1 Min #4 | Reloading chart. | 2020-09-25 22:57:03.869 DE10YY1 1 Min #5 | Reloading chart. | 2020-09-25 22:57:03.876 EURJPY 30 Min #6 | Reloading chart. | 2020-09-25 22:57:03.891 EURJPY 5 Min #7 | Reloading chart. | 2020-09-25 22:57:03.922 EURJPY 1 Min #8 | Reloading chart. | 2020-09-25 22:57:04.010 JPN225 1 Min #9 | Reloading chart. | 2020-09-25 22:57:04.018 GER30 1 Min #10 | Reloading chart. | 2020-09-25 22:57:04.026 TED1 30 Min #11 | Reloading chart. | 2020-09-25 22:57:04.201 USOil 5 Min #12 | Reloading chart. | 2020-09-25 22:57:04.313 USDOLLAR 1 Min #13 | Reloading chart. | 2020-09-25 22:57:04.322 AUDJPY 1 Min #14 | Reloading chart. | 2020-09-25 22:57:04.332 Chart #12 has tagged chart #8 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:07.093 Chart #11 has tagged chart #1 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:07.520 Chart #11 has tagged chart #8 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:07.520 Chart #14 has tagged chart #1 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:07.580 Chart #14 has tagged chart #7 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:07.580 Chart #14 has tagged chart #8 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:07.580 Chart #13 has tagged chart #8 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:07.601 Chart #15 has tagged chart #11 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:07.606 Chart #9 has tagged chart #1 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:07.698 Chart #9 has tagged chart #10 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:07.698 Symbol settings received. Request ID: 2. | 2020-09-25 22:57:07.713 Chart #13 has tagged chart #1 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:07.841 Chart #13 has tagged chart #7 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:07.841 Chart #13 has tagged chart #8 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:07.841 Chart #9 has tagged chart #1 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:07.857 Chart #9 has tagged chart #10 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:07.857 Chart #9 has tagged chart #1 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:07.860 Chart #10 has tagged chart #9 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:07.886 Chart #14 has tagged chart #8 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:08.246 Chart #12 has tagged chart #11 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:08.485 Using Bid/Ask average for last trade price for EURUSD | 2020-09-25 22:57:08.493 Starting DelayedDownloadMonitoringTimer | 2020-09-25 22:57:08.494 Starting HDTimeoutTimer | 2020-09-25 22:57:08.494 Added historical Intraday data request for EURUSD to the queue. | 2020-09-25 22:57:08.494 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2020-09-25 22:57:08.494 Triggering next historical data download in queue. | 2020-09-25 22:57:08.494 HD Request # 1 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2020-09-25 22:57:08.494 HD Request # 1 | Download start date-time: 2020-09-25 21:59:08.000 | 2020-09-25 22:57:08.494 HD Request # 1 | Using server: ds4.sierracharts.com port 10149 | 2020-09-25 22:57:08.494 Using Bid/Ask average for last trade price for GBPUSD | 2020-09-25 22:57:08.494 Added historical Intraday data request for GBPUSD to the queue. | 2020-09-25 22:57:08.495 Intraday data recording state for symbol GBPUSD is set to download 'Pending'. | 2020-09-25 22:57:08.495 Triggering next historical data download in queue. | 2020-09-25 22:57:08.495 Starting DelayedDownloadMonitoringTimer | 2020-09-25 22:57:08.506 Starting HDTimeoutTimer | 2020-09-25 22:57:08.506 Added historical Intraday data request for US10YY1 to the queue. | 2020-09-25 22:57:08.506 Intraday data recording state for symbol US10YY1 is set to download 'Pending'. | 2020-09-25 22:57:08.506 Triggering next historical data download in queue. | 2020-09-25 22:57:08.506 HD Request # 2 | Downloading Intraday chart data for US10YY1 to the file US10YY1.scid. Service: scdataallservices | 2020-09-25 22:57:08.506 HD Request # 2 | Download start date-time: 2020-09-25 22:56:03.000 | 2020-09-25 22:57:08.506 HD Request # 2 | Error downloading historical Intraday data for US10YY1. The futures symbol format is invalid. The year must be 2 digits. | 2020-09-25 22:57:08.507 HD Request # 2 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for US10YY1 | 2020-09-25 22:57:08.507 HD Request # 2 | Completion time: 0s | 2020-09-25 22:57:08.507 HD Request # 2 | Intraday data download complete for US10YY1. Unique request ID: 3 | 2020-09-25 22:57:08.507 Removing historical data download ID 3. | 2020-09-25 22:57:08.507 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:08.507 Triggering next historical data download in queue. | 2020-09-25 22:57:08.507 Added historical Intraday data request for US02YY1 to the queue. | 2020-09-25 22:57:08.507 Intraday data recording state for symbol US02YY1 is set to download 'Pending'. | 2020-09-25 22:57:08.507 Triggering next historical data download in queue. | 2020-09-25 22:57:08.507 HD Request # 3 | Downloading Intraday chart data for US02YY1 to the file US02YY1.scid. Service: scdataallservices | 2020-09-25 22:57:08.507 Socket (1) | Creating socket. | 2020-09-25 22:57:08.508 HD Request # 3 | Download start date-time: 2020-09-25 22:56:04.000 | 2020-09-25 22:57:08.508 HD Request # 3 | Error downloading historical Intraday data for US02YY1. The futures symbol format is invalid. The year must be 2 digits. | 2020-09-25 22:57:08.508 HD Request # 3 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for US02YY1 | 2020-09-25 22:57:08.508 Socket (1) | Connecting to IP: 192.81.56.146. | 2020-09-25 22:57:08.508 HD Request # 3 | Completion time: 0s | 2020-09-25 22:57:08.508 HD Request # 3 | Intraday data download complete for US02YY1. Unique request ID: 4 | 2020-09-25 22:57:08.508 Removing historical data download ID 4. | 2020-09-25 22:57:08.508 HD Request # 3 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:08.508 Triggering next historical data download in queue. | 2020-09-25 22:57:08.508 Added historical Intraday data request for GB02YY1 to the queue. | 2020-09-25 22:57:08.510 Intraday data recording state for symbol GB02YY1 is set to download 'Pending'. | 2020-09-25 22:57:08.510 Triggering next historical data download in queue. | 2020-09-25 22:57:08.510 HD Request # 4 | Downloading Intraday chart data for GB02YY1 to the file GB02YY1.scid. Service: scdataallservices | 2020-09-25 22:57:08.510 HD Request # 4 | Download start date-time: 2020-09-25 22:55:04.000 | 2020-09-25 22:57:08.510 HD Request # 4 | Error downloading historical Intraday data for GB02YY1. The futures symbol format is invalid. The year must be 2 digits. | 2020-09-25 22:57:08.510 HD Request # 4 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for GB02YY1 | 2020-09-25 22:57:08.510 HD Request # 4 | Completion time: 0s | 2020-09-25 22:57:08.510 HD Request # 4 | Intraday data download complete for GB02YY1. Unique request ID: 5 | 2020-09-25 22:57:08.510 Removing historical data download ID 5. | 2020-09-25 22:57:08.510 HD Request # 4 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:08.510 Triggering next historical data download in queue. | 2020-09-25 22:57:08.510 Added historical Intraday data request for GB10YY1 to the queue. | 2020-09-25 22:57:08.511 Intraday data recording state for symbol GB10YY1 is set to download 'Pending'. | 2020-09-25 22:57:08.511 Triggering next historical data download in queue. | 2020-09-25 22:57:08.511 HD Request # 5 | Downloading Intraday chart data for GB10YY1 to the file GB10YY1.scid. Service: scdataallservices | 2020-09-25 22:57:08.511 HD Request # 5 | Download start date-time: 2020-09-25 22:56:01.000 | 2020-09-25 22:57:08.511 HD Request # 5 | Error downloading historical Intraday data for GB10YY1. The futures symbol format is invalid. The year must be 2 digits. | 2020-09-25 22:57:08.511 HD Request # 5 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for GB10YY1 | 2020-09-25 22:57:08.511 HD Request # 5 | Completion time: 0s | 2020-09-25 22:57:08.511 HD Request # 5 | Intraday data download complete for GB10YY1. Unique request ID: 6 | 2020-09-25 22:57:08.511 Removing historical data download ID 6. | 2020-09-25 22:57:08.511 HD Request # 5 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:08.511 Triggering next historical data download in queue. | 2020-09-25 22:57:08.511 Using Bid/Ask average for last trade price for SPX500 | 2020-09-25 22:57:08.689 Added historical Intraday data request for SPX500 to the queue. | 2020-09-25 22:57:08.689 Intraday data recording state for symbol SPX500 is set to download 'Pending'. | 2020-09-25 22:57:08.689 Triggering next historical data download in queue. | 2020-09-25 22:57:08.689 Using Bid/Ask average for last trade price for UK100 | 2020-09-25 22:57:08.714 Added historical Intraday data request for UK100 to the queue. | 2020-09-25 22:57:08.714 Intraday data recording state for symbol UK100 is set to download 'Pending'. | 2020-09-25 22:57:08.714 Triggering next historical data download in queue. | 2020-09-25 22:57:08.714 Added historical Intraday data request for USDX to the queue. | 2020-09-25 22:57:08.714 Intraday data recording state for symbol USDX is set to download 'Pending'. | 2020-09-25 22:57:08.714 Triggering next historical data download in queue. | 2020-09-25 22:57:08.714 Using Bid/Ask average for last trade price for USDJPY | 2020-09-25 22:57:08.715 Added historical Intraday data request for USDJPY to the queue. | 2020-09-25 22:57:08.715 Intraday data recording state for symbol USDJPY is set to download 'Pending'. | 2020-09-25 22:57:08.715 Triggering next historical data download in queue. | 2020-09-25 22:57:08.715 Chart #2 has tagged chart #3 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:08.718 Chart #3 has tagged chart #1 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:08.718 Chart #3 has tagged chart #5 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:08.718 Chart #3 has tagged chart #7 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:08.718 Added historical Intraday data request for DE02YY1 to the queue. | 2020-09-25 22:57:08.718 Intraday data recording state for symbol DE02YY1 is set to download 'Pending'. | 2020-09-25 22:57:08.718 Triggering next historical data download in queue. | 2020-09-25 22:57:08.718 HD Request # 6 | Downloading Intraday chart data for DE02YY1 to the file DE02YY1.scid. Service: scdataallservices | 2020-09-25 22:57:08.719 HD Request # 6 | Download start date-time: 2020-09-25 22:56:01.000 | 2020-09-25 22:57:08.719 HD Request # 6 | Error downloading historical Intraday data for DE02YY1. The futures symbol format is invalid. The year must be 2 digits. | 2020-09-25 22:57:08.719 HD Request # 6 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for DE02YY1 | 2020-09-25 22:57:08.719 HD Request # 6 | Completion time: 0s | 2020-09-25 22:57:08.719 HD Request # 6 | Intraday data download complete for DE02YY1. Unique request ID: 11 | 2020-09-25 22:57:08.719 Removing historical data download ID 11. | 2020-09-25 22:57:08.719 HD Request # 6 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:08.719 Triggering next historical data download in queue. | 2020-09-25 22:57:08.719 Added historical Intraday data request for DE10YY1 to the queue. | 2020-09-25 22:57:08.720 Intraday data recording state for symbol DE10YY1 is set to download 'Pending'. | 2020-09-25 22:57:08.720 Triggering next historical data download in queue. | 2020-09-25 22:57:08.720 HD Request # 7 | Downloading Intraday chart data for DE10YY1 to the file DE10YY1.scid. Service: scdataallservices | 2020-09-25 22:57:08.720 HD Request # 7 | Download start date-time: 2020-09-25 22:56:02.000 | 2020-09-25 22:57:08.721 HD Request # 7 | Error downloading historical Intraday data for DE10YY1. The futures symbol format is invalid. The year must be 2 digits. | 2020-09-25 22:57:08.721 HD Request # 7 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for DE10YY1 | 2020-09-25 22:57:08.721 HD Request # 7 | Completion time: 0s | 2020-09-25 22:57:08.721 HD Request # 7 | Intraday data download complete for DE10YY1. Unique request ID: 12 | 2020-09-25 22:57:08.721 Removing historical data download ID 12. | 2020-09-25 22:57:08.721 HD Request # 7 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:08.721 Triggering next historical data download in queue. | 2020-09-25 22:57:08.721 HD Request # 1 | Setting DTC encoding to Binary VLS | 2020-09-25 22:57:08.740 HD Request # 1 | Sending historical data logon request message. | 2020-09-25 22:57:08.740 Using Bid/Ask average for last trade price for GER30 | 2020-09-25 22:57:08.762 Added historical Intraday data request for GER30 to the queue. | 2020-09-25 22:57:08.762 Intraday data recording state for symbol GER30 is set to download 'Pending'. | 2020-09-25 22:57:08.762 Triggering next historical data download in queue. | 2020-09-25 22:57:08.762 Using Bid/Ask average for last trade price for EURJPY | 2020-09-25 22:57:08.767 Added historical Intraday data request for EURJPY to the queue. | 2020-09-25 22:57:08.767 Intraday data recording state for symbol EURJPY is set to download 'Pending'. | 2020-09-25 22:57:08.767 Triggering next historical data download in queue. | 2020-09-25 22:57:08.767 Starting DelayedDownloadMonitoringTimer | 2020-09-25 22:57:08.845 Starting HDTimeoutTimer | 2020-09-25 22:57:08.845 Added historical Intraday data request for {DE10YY1}-{US10YY1} to the queue. | 2020-09-25 22:57:08.845 Intraday data recording state for symbol {DE10YY1}-{US10YY1} is set to download 'Pending'. | 2020-09-25 22:57:08.845 Triggering next historical data download in queue. | 2020-09-25 22:57:08.845 HD Request # 8 | Downloading Intraday chart data for {DE10YY1}-{US10YY1} to the file {DE10YY1}-{US10YY1}.scid. Service: | 2020-09-25 22:57:08.846 HD Request # 8 | Download start date-time: 2020-08-26 17:20:01.000 | 2020-09-25 22:57:08.846 HD Request # 8 | Initiating download of DE10YY1 for {DE10YY1}-{US10YY1}. | 2020-09-25 22:57:08.846 Added historical Intraday data request for DE10YY1 to the queue. | 2020-09-25 22:57:08.846 Intraday data recording state for symbol DE10YY1 is set to download 'Pending'. | 2020-09-25 22:57:08.846 Triggering next historical data download in queue. | 2020-09-25 22:57:08.846 HD Request # 8 | Initiating download of US10YY1 for {DE10YY1}-{US10YY1}. | 2020-09-25 22:57:08.846 Added historical Intraday data request for US10YY1 to the queue. | 2020-09-25 22:57:08.846 Intraday data recording state for symbol US10YY1 is set to download 'Pending'. | 2020-09-25 22:57:08.846 HD Request # 9 | Downloading Intraday chart data for DE10YY1 to the file DE10YY1.scid. Service: scdataallservices | 2020-09-25 22:57:08.846 HD Request # 9 | Download start date-time: 2020-09-25 22:56:02.000 | 2020-09-25 22:57:08.847 HD Request # 9 | Error downloading historical Intraday data for DE10YY1. The futures symbol format is invalid. The year must be 2 digits. | 2020-09-25 22:57:08.847 HD Request # 9 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for DE10YY1 | 2020-09-25 22:57:08.847 HD Request # 9 | Completion time: 0s | 2020-09-25 22:57:08.847 HD Request # 9 | Intraday data download complete for DE10YY1. Unique request ID: 16 | 2020-09-25 22:57:08.847 Removing historical data download ID 16. | 2020-09-25 22:57:08.847 HD Request # 9 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:08.847 Triggering next historical data download in queue. | 2020-09-25 22:57:08.847 HD Request # 10 | Downloading Intraday chart data for US10YY1 to the file US10YY1.scid. Service: scdataallservices | 2020-09-25 22:57:08.847 HD Request # 10 | Download start date-time: 2020-09-25 22:56:03.000 | 2020-09-25 22:57:08.847 HD Request # 10 | Error downloading historical Intraday data for US10YY1. The futures symbol format is invalid. The year must be 2 digits. | 2020-09-25 22:57:08.847 HD Request # 10 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for US10YY1 | 2020-09-25 22:57:08.847 HD Request # 10 | Completion time: 0s | 2020-09-25 22:57:08.847 HD Request # 10 | Intraday data download complete for US10YY1. Unique request ID: 17 | 2020-09-25 22:57:08.847 Removing historical data download ID 17. | 2020-09-25 22:57:08.847 HD Request # 8 | Calculating bar data for {DE10YY1}-{US10YY1}. | 2020-09-25 22:57:08.847 HD Request # 10 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:08.847 Triggering next historical data download in queue. | 2020-09-25 22:57:08.847 Added historical Intraday data request for USD-X to the queue. | 2020-09-25 22:57:08.849 Intraday data recording state for symbol USD-X is set to download 'Pending'. | 2020-09-25 22:57:08.849 Triggering next historical data download in queue. | 2020-09-25 22:57:08.851 Added historical Intraday data request for JP02YY1 to the queue. | 2020-09-25 22:57:08.867 Intraday data recording state for symbol JP02YY1 is set to download 'Pending'. | 2020-09-25 22:57:08.867 Triggering next historical data download in queue. | 2020-09-25 22:57:08.867 HD Request # 11 | Downloading Intraday chart data for JP02YY1 to the file JP02YY1.scid. Service: scdataallservices | 2020-09-25 22:57:08.868 HD Request # 11 | Download start date-time: 2020-09-25 22:57:04.000 | 2020-09-25 22:57:08.869 HD Request # 11 | Error downloading historical Intraday data for JP02YY1. The futures symbol format is invalid. The year must be 2 digits. | 2020-09-25 22:57:08.869 HD Request # 11 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for JP02YY1 | 2020-09-25 22:57:08.869 HD Request # 11 | Completion time: 0s | 2020-09-25 22:57:08.869 HD Request # 11 | Intraday data download complete for JP02YY1. Unique request ID: 19 | 2020-09-25 22:57:08.869 Removing historical data download ID 19. | 2020-09-25 22:57:08.869 HD Request # 11 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:08.869 Triggering next historical data download in queue. | 2020-09-25 22:57:08.869 Added historical Intraday data request for JP10YY1 to the queue. | 2020-09-25 22:57:08.871 Intraday data recording state for symbol JP10YY1 is set to download 'Pending'. | 2020-09-25 22:57:08.871 Triggering next historical data download in queue. | 2020-09-25 22:57:08.871 HD Request # 12 | Downloading Intraday chart data for JP10YY1 to the file JP10YY1.scid. Service: scdataallservices | 2020-09-25 22:57:08.872 HD Request # 12 | Download start date-time: 2020-09-25 22:57:02.000 | 2020-09-25 22:57:08.872 HD Request # 12 | Error downloading historical Intraday data for JP10YY1. The futures symbol format is invalid. The year must be 2 digits. | 2020-09-25 22:57:08.872 HD Request # 12 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for JP10YY1 | 2020-09-25 22:57:08.872 HD Request # 12 | Completion time: 0s | 2020-09-25 22:57:08.872 HD Request # 12 | Intraday data download complete for JP10YY1. Unique request ID: 20 | 2020-09-25 22:57:08.872 Removing historical data download ID 20. | 2020-09-25 22:57:08.872 HD Request # 12 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:08.872 Triggering next historical data download in queue. | 2020-09-25 22:57:08.872 Chart #5 has tagged chart #1 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:08.872 Chart #5 has tagged chart #7 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:08.872 Chart #5 has tagged chart #8 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:08.872 Chart #4 has tagged chart #5 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:08.874 Using Bid/Ask average for last trade price for JPN225 | 2020-09-25 22:57:08.920 Added historical Intraday data request for JPN225 to the queue. | 2020-09-25 22:57:08.920 Intraday data recording state for symbol JPN225 is set to download 'Pending'. | 2020-09-25 22:57:08.920 Triggering next historical data download in queue. | 2020-09-25 22:57:08.920 Using Bid/Ask average for last trade price for USOil | 2020-09-25 22:57:08.948 Added historical Intraday data request for USOil to the queue. | 2020-09-25 22:57:08.948 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2020-09-25 22:57:08.948 Triggering next historical data download in queue. | 2020-09-25 22:57:08.949 Using Bid/Ask average for last trade price for USDOLLAR | 2020-09-25 22:57:08.955 Added historical Intraday data request for USDOLLAR to the queue. | 2020-09-25 22:57:08.955 Intraday data recording state for symbol USDOLLAR is set to download 'Pending'. | 2020-09-25 22:57:08.955 Triggering next historical data download in queue. | 2020-09-25 22:57:08.955 Using Bid/Ask average for last trade price for AUDJPY | 2020-09-25 22:57:08.963 Added historical Intraday data request for AUDJPY to the queue. | 2020-09-25 22:57:08.963 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2020-09-25 22:57:08.963 Triggering next historical data download in queue. | 2020-09-25 22:57:08.963 SC Data - All Services | Connected to server complete. | 2020-09-25 22:57:08.968 Triggering next historical data download in queue. | 2020-09-25 22:57:08.968 Triggering next historical data download in queue. | 2020-09-25 22:57:08.968 Triggering next historical data download in queue. | 2020-09-25 22:57:08.968 Triggering next historical data download in queue. | 2020-09-25 22:57:08.968 Triggering next historical data download in queue. | 2020-09-25 22:57:08.968 Chart #2 has tagged chart #3 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:08.969 Chart #3 has tagged chart #1 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:08.970 Chart #3 has tagged chart #5 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:08.970 Chart #3 has tagged chart #7 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:08.970 Chart #4 has tagged chart #5 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:08.970 Chart #5 has tagged chart #1 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:08.970 Chart #5 has tagged chart #7 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:08.970 Chart #4 has tagged chart #5 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:08.999 Chart #5 has tagged chart #1 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:08.999 Chart #5 has tagged chart #7 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:08.999 Chart #2 has tagged chart #3 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:09.015 Chart #3 has tagged chart #1 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:09.015 Chart #3 has tagged chart #5 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:09.015 Chart #3 has tagged chart #7 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:09.015 Chart #3 has tagged chart #8 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:09.015 Using Bid/Ask average for last trade price for EURUSD | 2020-09-25 22:57:09.020 SC DTC Data with Market Depth | Starting real-time market data updates for: EURUSD. ID: 1 Service code: fxcm | 2020-09-25 22:57:09.020 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2020-09-25 22:57:09.020 SC DTC Data with Market Depth | Requesting security definition data for: EURUSD. ID: 1 | 2020-09-25 22:57:09.020 DTC Client socket (2) | Creating socket. | 2020-09-25 22:57:09.020 DTC Client socket (2) | Connecting to IP: 192.81.56.146. | 2020-09-25 22:57:09.020 Using Bid/Ask average for last trade price for GBPUSD | 2020-09-25 22:57:09.021 SC DTC Data with Market Depth | Starting real-time market data updates for: GBPUSD. ID: 2 Service code: fxcm | 2020-09-25 22:57:09.021 SC DTC Data with Market Depth | Requesting security definition data for: GBPUSD. ID: 2 | 2020-09-25 22:57:09.021 SC Data - All Services | Starting real-time market data updates for: US10YY1. ID: 3 | 2020-09-25 22:57:09.022 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: US10YY1 | 2020-09-25 22:57:09.022 SC Data - All Services | Requesting security definition data for: US10YY1. ID: 3 | 2020-09-25 22:57:09.022 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:09.022 * SC Data - All Services | Starting real-time market data updates for: US02YY1. ID: 4 | 2020-09-25 22:57:09.022 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: US02YY1 | 2020-09-25 22:57:09.022 SC Data - All Services | Requesting security definition data for: US02YY1. ID: 4 | 2020-09-25 22:57:09.022 Added historical Intraday data request for US02YY1 to the queue. | 2020-09-25 22:57:09.022 Intraday data recording state for symbol US02YY1 is set to download 'Pending'. | 2020-09-25 22:57:09.022 Triggering next historical data download in queue. | 2020-09-25 22:57:09.022 Delaying start of download for US02YY1 | 2020-09-25 22:57:09.022 SC Data - All Services | Starting real-time market data updates for: GB02YY1. ID: 5 | 2020-09-25 22:57:09.022 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: GB02YY1 | 2020-09-25 22:57:09.022 SC Data - All Services | Requesting security definition data for: GB02YY1. ID: 5 | 2020-09-25 22:57:09.022 Added historical Intraday data request for GB02YY1 to the queue. | 2020-09-25 22:57:09.022 Intraday data recording state for symbol GB02YY1 is set to download 'Pending'. | 2020-09-25 22:57:09.022 Triggering next historical data download in queue. | 2020-09-25 22:57:09.022 SC Data - All Services | Starting real-time market data updates for: GB10YY1. ID: 6 | 2020-09-25 22:57:09.023 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: GB10YY1 | 2020-09-25 22:57:09.023 SC Data - All Services | Requesting security definition data for: GB10YY1. ID: 6 | 2020-09-25 22:57:09.023 Added historical Intraday data request for GB10YY1 to the queue. | 2020-09-25 22:57:09.023 Intraday data recording state for symbol GB10YY1 is set to download 'Pending'. | 2020-09-25 22:57:09.023 Triggering next historical data download in queue. | 2020-09-25 22:57:09.023 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:09.030 * SC DTC Data with Market Depth | Network connection to server complete. | 2020-09-25 22:57:09.161 SC DTC Data with Market Depth | Starting socket receive thread. | 2020-09-25 22:57:09.161 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2020-09-25 22:57:09.162 Using Bid/Ask average for last trade price for SPX500 | 2020-09-25 22:57:09.188 SC DTC Data with Market Depth | Starting real-time market data updates for: SPX500. ID: 7 Service code: fxcm | 2020-09-25 22:57:09.188 SC DTC Data with Market Depth | Requesting security definition data for: SPX500. ID: 7 | 2020-09-25 22:57:09.188 Using Bid/Ask average for last trade price for UK100 | 2020-09-25 22:57:09.196 SC DTC Data with Market Depth | Starting real-time market data updates for: UK100. ID: 8 Service code: fxcm | 2020-09-25 22:57:09.196 SC DTC Data with Market Depth | Requesting security definition data for: UK100. ID: 8 | 2020-09-25 22:57:09.196 SC DTC Data with Market Depth | Starting real-time market data updates for: USDX. ID: 9 Service code: fxstatscalc | 2020-09-25 22:57:09.196 SC DTC Data with Market Depth | Requesting security definition data for: USDX. ID: 9 | 2020-09-25 22:57:09.196 Using Bid/Ask average for last trade price for USDJPY | 2020-09-25 22:57:09.198 SC DTC Data with Market Depth | Starting real-time market data updates for: USDJPY. ID: 10 Service code: fxcm | 2020-09-25 22:57:09.199 SC DTC Data with Market Depth | Requesting security definition data for: USDJPY. ID: 10 | 2020-09-25 22:57:09.199 SC Data - All Services | Starting real-time market data updates for: DE10YY1. ID: 11 | 2020-09-25 22:57:09.200 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: DE10YY1 | 2020-09-25 22:57:09.200 SC Data - All Services | Requesting security definition data for: DE10YY1. ID: 11 | 2020-09-25 22:57:09.200 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:09.200 * Using Bid/Ask average for last trade price for EURJPY | 2020-09-25 22:57:09.200 SC DTC Data with Market Depth | Starting real-time market data updates for: EURJPY. ID: 12 Service code: fxcm | 2020-09-25 22:57:09.201 SC DTC Data with Market Depth | Requesting security definition data for: EURJPY. ID: 12 | 2020-09-25 22:57:09.201 SC Data - All Services | Starting real-time market data updates for: DE02YY1. ID: 13 | 2020-09-25 22:57:09.256 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: DE02YY1 | 2020-09-25 22:57:09.256 SC Data - All Services | Requesting security definition data for: DE02YY1. ID: 13 | 2020-09-25 22:57:09.256 Added historical Intraday data request for DE02YY1 to the queue. | 2020-09-25 22:57:09.256 Intraday data recording state for symbol DE02YY1 is set to download 'Pending'. | 2020-09-25 22:57:09.256 Triggering next historical data download in queue. | 2020-09-25 22:57:09.256 SC Data - All Services | Not subscribing to real-time market data updates directly because it is a composite or formula symbol. {DE10YY1}-{US10YY1}. ID: 14 | 2020-09-25 22:57:09.281 SC DTC Data with Market Depth | Starting real-time market data updates for: USD-X. ID: 15 Service code: fxstatscalc | 2020-09-25 22:57:09.282 SC DTC Data with Market Depth | Requesting security definition data for: USD-X. ID: 15 | 2020-09-25 22:57:09.282 Using Bid/Ask average for last trade price for USOil | 2020-09-25 22:57:09.282 SC DTC Data with Market Depth | Starting real-time market data updates for: USOil. ID: 16 Service code: fxcm | 2020-09-25 22:57:09.282 SC DTC Data with Market Depth | Requesting security definition data for: USOil. ID: 16 | 2020-09-25 22:57:09.282 Using Bid/Ask average for last trade price for GER30 | 2020-09-25 22:57:09.289 SC DTC Data with Market Depth | Starting real-time market data updates for: GER30. ID: 17 Service code: fxcm | 2020-09-25 22:57:09.289 SC DTC Data with Market Depth | Requesting security definition data for: GER30. ID: 17 | 2020-09-25 22:57:09.289 Using Bid/Ask average for last trade price for JPN225 | 2020-09-25 22:57:09.290 SC DTC Data with Market Depth | Starting real-time market data updates for: JPN225. ID: 18 Service code: fxcm | 2020-09-25 22:57:09.290 SC DTC Data with Market Depth | Requesting security definition data for: JPN225. ID: 18 | 2020-09-25 22:57:09.290 HD Request # 1 | Requesting Intraday data. Start date-time: 2020-09-25 21:59:08. Record interval: 0. Symbol: EURUSD | 2020-09-25 22:57:09.315 Using Bid/Ask average for last trade price for USDOLLAR | 2020-09-25 22:57:09.320 SC DTC Data with Market Depth | Starting real-time market data updates for: USDOLLAR. ID: 19 Service code: fxcm | 2020-09-25 22:57:09.320 SC DTC Data with Market Depth | Requesting security definition data for: USDOLLAR. ID: 19 | 2020-09-25 22:57:09.320 Using Bid/Ask average for last trade price for AUDJPY | 2020-09-25 22:57:09.331 SC DTC Data with Market Depth | Starting real-time market data updates for: AUDJPY. ID: 20 Service code: fxcm | 2020-09-25 22:57:09.331 SC DTC Data with Market Depth | Requesting security definition data for: AUDJPY. ID: 20 | 2020-09-25 22:57:09.331 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:09.335 * SC Data - All Services | Starting real-time market data updates for: JP02YY1. ID: 21 | 2020-09-25 22:57:09.335 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: JP02YY1 | 2020-09-25 22:57:09.335 SC Data - All Services | Requesting security definition data for: JP02YY1. ID: 21 | 2020-09-25 22:57:09.335 Added historical Intraday data request for JP02YY1 to the queue. | 2020-09-25 22:57:09.335 Intraday data recording state for symbol JP02YY1 is set to download 'Pending'. | 2020-09-25 22:57:09.335 Triggering next historical data download in queue. | 2020-09-25 22:57:09.335 SC Data - All Services | Starting real-time market data updates for: JP10YY1. ID: 22 | 2020-09-25 22:57:09.336 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: JP10YY1 | 2020-09-25 22:57:09.336 SC Data - All Services | Requesting security definition data for: JP10YY1. ID: 22 | 2020-09-25 22:57:09.336 Added historical Intraday data request for JP10YY1 to the queue. | 2020-09-25 22:57:09.336 Intraday data recording state for symbol JP10YY1 is set to download 'Pending'. | 2020-09-25 22:57:09.336 Triggering next historical data download in queue. | 2020-09-25 22:57:09.336 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:09.336 * SC Data - All Services | Starting real-time market data updates for: TED1. ID: 23 | 2020-09-25 22:57:09.339 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: TED1 | 2020-09-25 22:57:09.339 SC Data - All Services | Requesting security definition data for: TED1. ID: 23 | 2020-09-25 22:57:09.339 No historical data client is currently set to download historical Intraday data for TED1. | 2020-09-25 22:57:09.339 Real-time Intraday chart data file updates started for TED1 | 2020-09-25 22:57:09.339 Intraday chart data file opened for TED1 | 2020-09-25 22:57:09.339 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:09.342 * SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2020-09-25 22:57:09.348 SC DTC Data with Market Depth | Sending logon request message. | 2020-09-25 22:57:09.348 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:09.353 * HD Request # 1 | Decompressing data. | 2020-09-25 22:57:09.425 HD Request # 1 | Receiving Intraday data for EURUSD starting at 2020-09-25 21:59:08.164000 | 2020-09-25 22:57:09.426 Socket (1) | CloseSocket call. | 2020-09-25 22:57:09.426 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-25 22:57:09.426 HD Request # 1 | Re-requesting historical data for EURUSD to get the latest data since the download was started while not connected to primary service. | 2020-09-25 22:57:09.426 Added historical Intraday data request for EURUSD to the queue. | 2020-09-25 22:57:09.426 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2020-09-25 22:57:09.426 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-09-25 22:57:09.426 Triggering next historical data download in queue. | 2020-09-25 22:57:09.426 Historical data download thread signaled to stop. | 2020-09-25 22:57:09.426 HD Request # 1 | Timestamp of first Intraday data file record written: 2020-09-25 21:59:08.164001 | 2020-09-25 22:57:09.427 HD Request # 1 | Received 1 record from 2020-09-25 21:59:08.164 to 2020-09-25 21:59:08.164 (0.0 seconds) and wrote 1 record for EURUSD | 2020-09-25 22:57:09.427 HD Request # 1 | Completion time: 1s | 2020-09-25 22:57:09.427 Delaying start of download for EURUSD | 2020-09-25 22:57:09.427 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:09.492 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:09.492 * Socket (1) | Socket gracefully closed by remote side. | 2020-09-25 22:57:09.539 Socket (1) | Closed. | 2020-09-25 22:57:09.539 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:09.602 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:09.664 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:09.808 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:09.808 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:09.917 * SC DTC Data with Market Depth | Received logon response. | 2020-09-25 22:57:09.965 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2020-09-25 22:57:09.965 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2020-09-25 22:57:09.965 SC DTC Data with Market Depth | Successfully connected. | 2020-09-25 22:57:09.965 SC DTC Data with Market Depth | Trading is not supported. | 2020-09-25 22:57:09.965 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDJPY | 2020-09-25 22:57:09.965 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURJPY | 2020-09-25 22:57:09.965 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2020-09-25 22:57:09.965 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPUSD | 2020-09-25 22:57:09.965 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GER30 | 2020-09-25 22:57:09.965 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: JPN225 | 2020-09-25 22:57:09.965 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2020-09-25 22:57:09.965 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: UK100 | 2020-09-25 22:57:09.965 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USD-X | 2020-09-25 22:57:09.965 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDJPY | 2020-09-25 22:57:09.965 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDOLLAR | 2020-09-25 22:57:09.965 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDX | 2020-09-25 22:57:09.965 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2020-09-25 22:57:09.965 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:09.981 * SC DTC Data with Market Depth | Received security definition for symbol AUDJPY | 2020-09-25 22:57:10.180 SC DTC Data with Market Depth | Received security definition for symbol EURJPY | 2020-09-25 22:57:10.180 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2020-09-25 22:57:10.180 SC DTC Data with Market Depth | Received security definition for symbol GBPUSD | 2020-09-25 22:57:10.180 SC DTC Data with Market Depth | Received security definition for symbol GER30 | 2020-09-25 22:57:10.180 SC DTC Data with Market Depth | Received security definition for symbol JPN225 | 2020-09-25 22:57:10.180 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:10.181 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:10.202 * SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2020-09-25 22:57:10.244 SC DTC Data with Market Depth | Received security definition for symbol UK100 | 2020-09-25 22:57:10.244 SC DTC Data with Market Depth | Received security definition for symbol USD-X | 2020-09-25 22:57:10.244 SC DTC Data with Market Depth | Received security definition for symbol USDJPY | 2020-09-25 22:57:10.244 SC DTC Data with Market Depth | Received security definition for symbol USDOLLAR | 2020-09-25 22:57:10.244 SC DTC Data with Market Depth | Received security definition for symbol USDX | 2020-09-25 22:57:10.244 SC DTC Data with Market Depth | Received security definition for symbol USOil | 2020-09-25 22:57:10.244 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:10.250 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:10.587 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:10.667 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:10.667 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:10.675 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:10.691 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:10.747 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:10.753 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:10.859 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:10.947 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:11.065 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:11.065 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:11.161 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:11.225 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:11.369 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:11.369 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:11.480 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:11.544 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:11.689 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:11.689 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:11.789 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:57:11.832 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:11.848 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:11.992 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:11.993 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:12.104 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:12.168 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:12.312 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:12.313 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:12.422 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:12.486 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:12.614 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:12.614 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:12.726 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:12.794 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:12.934 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:12.934 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:13.045 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:13.109 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:13.238 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:13.238 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:13.349 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:13.413 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:13.556 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:13.556 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:13.666 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:13.728 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:13.872 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:13.872 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:13.982 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:14.045 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:14.189 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:14.190 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:14.288 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:14.349 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:14.491 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:14.492 * HD Request # 13 | Downloading Intraday chart data for US02YY1 to the file US02YY1.scid. Service: scdataallservices | 2020-09-25 22:57:14.507 HD Request # 13 | Download start date-time: 2020-09-25 22:56:04.000 | 2020-09-25 22:57:14.508 HD Request # 13 | Error downloading historical Intraday data for US02YY1. The futures symbol format is invalid. The year must be 2 digits. | 2020-09-25 22:57:14.508 HD Request # 13 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for US02YY1 | 2020-09-25 22:57:14.508 HD Request # 13 | Completion time: 0s | 2020-09-25 22:57:14.508 HD Request # 13 | Intraday data download complete for US02YY1. Unique request ID: 25 | 2020-09-25 22:57:14.508 Removing historical data download ID 25. | 2020-09-25 22:57:14.508 Real-time Intraday chart data file updates started for US02YY1 | 2020-09-25 22:57:14.508 Intraday chart data file opened for US02YY1 | 2020-09-25 22:57:14.508 HD Request # 13 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:14.508 Triggering next historical data download in queue. | 2020-09-25 22:57:14.508 HD Request # 14 | Downloading Intraday chart data for GB02YY1 to the file GB02YY1.scid. Service: scdataallservices | 2020-09-25 22:57:14.508 HD Request # 14 | Download start date-time: 2020-09-25 22:55:04.000 | 2020-09-25 22:57:14.509 HD Request # 14 | Error downloading historical Intraday data for GB02YY1. The futures symbol format is invalid. The year must be 2 digits. | 2020-09-25 22:57:14.509 HD Request # 14 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for GB02YY1 | 2020-09-25 22:57:14.509 HD Request # 14 | Completion time: 0s | 2020-09-25 22:57:14.509 HD Request # 14 | Intraday data download complete for GB02YY1. Unique request ID: 26 | 2020-09-25 22:57:14.509 Removing historical data download ID 26. | 2020-09-25 22:57:14.509 Real-time Intraday chart data file updates started for GB02YY1 | 2020-09-25 22:57:14.509 Intraday chart data file opened for GB02YY1 | 2020-09-25 22:57:14.509 HD Request # 14 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:14.509 Triggering next historical data download in queue. | 2020-09-25 22:57:14.509 HD Request # 15 | Downloading Intraday chart data for GB10YY1 to the file GB10YY1.scid. Service: scdataallservices | 2020-09-25 22:57:14.509 HD Request # 15 | Download start date-time: 2020-09-25 22:56:01.000 | 2020-09-25 22:57:14.510 HD Request # 15 | Error downloading historical Intraday data for GB10YY1. The futures symbol format is invalid. The year must be 2 digits. | 2020-09-25 22:57:14.510 HD Request # 15 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for GB10YY1 | 2020-09-25 22:57:14.510 HD Request # 15 | Completion time: 0s | 2020-09-25 22:57:14.510 HD Request # 15 | Intraday data download complete for GB10YY1. Unique request ID: 27 | 2020-09-25 22:57:14.510 Removing historical data download ID 27. | 2020-09-25 22:57:14.510 Real-time Intraday chart data file updates started for GB10YY1 | 2020-09-25 22:57:14.510 Intraday chart data file opened for GB10YY1 | 2020-09-25 22:57:14.510 HD Request # 15 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:14.510 Triggering next historical data download in queue. | 2020-09-25 22:57:14.510 HD Request # 16 | Downloading Intraday chart data for DE02YY1 to the file DE02YY1.scid. Service: scdataallservices | 2020-09-25 22:57:14.510 HD Request # 16 | Download start date-time: 2020-09-25 22:56:01.000 | 2020-09-25 22:57:14.510 HD Request # 16 | Error downloading historical Intraday data for DE02YY1. The futures symbol format is invalid. The year must be 2 digits. | 2020-09-25 22:57:14.510 HD Request # 16 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for DE02YY1 | 2020-09-25 22:57:14.510 HD Request # 16 | Completion time: 0s | 2020-09-25 22:57:14.511 HD Request # 16 | Intraday data download complete for DE02YY1. Unique request ID: 28 | 2020-09-25 22:57:14.511 Removing historical data download ID 28. | 2020-09-25 22:57:14.511 Real-time Intraday chart data file updates started for DE02YY1 | 2020-09-25 22:57:14.511 Intraday chart data file opened for DE02YY1 | 2020-09-25 22:57:14.511 HD Request # 16 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:14.511 Triggering next historical data download in queue. | 2020-09-25 22:57:14.511 HD Request # 17 | Downloading Intraday chart data for JP02YY1 to the file JP02YY1.scid. Service: scdataallservices | 2020-09-25 22:57:14.511 HD Request # 17 | Download start date-time: 2020-09-25 22:57:04.000 | 2020-09-25 22:57:14.511 HD Request # 17 | Error downloading historical Intraday data for JP02YY1. The futures symbol format is invalid. The year must be 2 digits. | 2020-09-25 22:57:14.511 HD Request # 17 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for JP02YY1 | 2020-09-25 22:57:14.511 HD Request # 17 | Completion time: 0s | 2020-09-25 22:57:14.512 HD Request # 17 | Intraday data download complete for JP02YY1. Unique request ID: 29 | 2020-09-25 22:57:14.512 Removing historical data download ID 29. | 2020-09-25 22:57:14.512 Real-time Intraday chart data file updates started for JP02YY1 | 2020-09-25 22:57:14.512 Intraday chart data file opened for JP02YY1 | 2020-09-25 22:57:14.512 HD Request # 17 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:14.512 Triggering next historical data download in queue. | 2020-09-25 22:57:14.512 HD Request # 18 | Downloading Intraday chart data for JP10YY1 to the file JP10YY1.scid. Service: scdataallservices | 2020-09-25 22:57:14.512 HD Request # 18 | Download start date-time: 2020-09-25 22:57:02.000 | 2020-09-25 22:57:14.512 HD Request # 18 | Error downloading historical Intraday data for JP10YY1. The futures symbol format is invalid. The year must be 2 digits. | 2020-09-25 22:57:14.512 HD Request # 18 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for JP10YY1 | 2020-09-25 22:57:14.512 HD Request # 18 | Completion time: 0s | 2020-09-25 22:57:14.512 HD Request # 18 | Intraday data download complete for JP10YY1. Unique request ID: 30 | 2020-09-25 22:57:14.512 Removing historical data download ID 30. | 2020-09-25 22:57:14.512 Real-time Intraday chart data file updates started for JP10YY1 | 2020-09-25 22:57:14.512 Intraday chart data file opened for JP10YY1 | 2020-09-25 22:57:14.512 HD Request # 18 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:14.512 Triggering next historical data download in queue. | 2020-09-25 22:57:14.512 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:14.603 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:14.667 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:14.811 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:14.811 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:57:14.842 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:14.922 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:14.986 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:15.114 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:15.115 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:15.224 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:15.293 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:15.432 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:15.433 * HD Request # 19 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2020-09-25 22:57:15.496 HD Request # 19 | Download start date-time: 2020-09-25 21:59:08.000 | 2020-09-25 22:57:15.496 HD Request # 19 | Using server: ds12.sierracharts.com port 10150 | 2020-09-25 22:57:15.496 Socket (1) | Creating socket. | 2020-09-25 22:57:15.503 Socket (1) | Connecting to IP: 204.15.197.14. | 2020-09-25 22:57:15.503 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:15.545 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:15.608 * HD Request # 19 | Setting DTC encoding to Binary VLS | 2020-09-25 22:57:15.752 HD Request # 19 | Sending historical data logon request message. | 2020-09-25 22:57:15.752 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:15.752 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:15.753 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:15.862 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:15.924 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:16.054 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:16.054 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:16.164 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:16.227 * HD Request # 19 | Requesting Intraday data. Start date-time: 2020-09-25 21:59:08. Record interval: 0. Symbol: EURUSD | 2020-09-25 22:57:16.316 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:16.372 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:16.372 * HD Request # 19 | Decompressing data. | 2020-09-25 22:57:16.440 HD Request # 19 | Receiving Intraday data for EURUSD starting at 2020-09-25 21:59:08.164000 | 2020-09-25 22:57:16.440 Socket (1) | CloseSocket call. | 2020-09-25 22:57:16.441 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-25 22:57:16.441 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-09-25 22:57:16.441 Historical data download thread signaled to stop. | 2020-09-25 22:57:16.441 HD Request # 19 | Timestamp of first Intraday data file record written: 2020-09-25 21:59:08.164002 | 2020-09-25 22:57:16.441 HD Request # 19 | Received 1 record from 2020-09-25 21:59:08.164 to 2020-09-25 21:59:08.164 (0.0 seconds) and wrote 1 record for EURUSD | 2020-09-25 22:57:16.441 HD Request # 19 | Completion time: 1s | 2020-09-25 22:57:16.442 HD Request # 19 | Intraday data download complete for EURUSD. Unique request ID: 1 | 2020-09-25 22:57:16.442 Removing historical data download ID 1. | 2020-09-25 22:57:16.442 Real-time Intraday chart data file updates started for EURUSD | 2020-09-25 22:57:16.442 Intraday chart data file opened for EURUSD | 2020-09-25 22:57:16.442 HD Request # 19 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:16.442 Triggering next historical data download in queue. | 2020-09-25 22:57:16.442 HD Request # 20 | Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: fxcm | 2020-09-25 22:57:16.442 HD Request # 20 | Download start date-time: 2020-09-25 21:59:03.000 | 2020-09-25 22:57:16.442 HD Request # 20 | Using server: ds3.sierracharts.com port 10149 | 2020-09-25 22:57:16.442 Socket (3) | Creating socket. | 2020-09-25 22:57:16.451 Socket (3) | Connecting to IP: 65.182.172.42. | 2020-09-25 22:57:16.451 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:16.482 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:16.545 * Socket (1) | Socket gracefully closed by remote side. | 2020-09-25 22:57:16.548 Socket (1) | Closed. | 2020-09-25 22:57:16.548 HD Request # 20 | Setting DTC encoding to Binary VLS | 2020-09-25 22:57:16.659 HD Request # 20 | Sending historical data logon request message. | 2020-09-25 22:57:16.659 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:16.688 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:16.688 * HD Request # 20 | Requesting Intraday data. Start date-time: 2020-09-25 21:59:03. Record interval: 0. Symbol: GBPUSD | 2020-09-25 22:57:16.749 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:16.799 * HD Request # 20 | Decompressing data. | 2020-09-25 22:57:16.847 HD Request # 20 | Receiving Intraday data for GBPUSD starting at 2020-09-25 21:59:03.242000 | 2020-09-25 22:57:16.847 Socket (3) | CloseSocket call. | 2020-09-25 22:57:16.847 Socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-25 22:57:16.847 Socket (3) | Shutdown started. Waiting for graceful close. | 2020-09-25 22:57:16.847 Historical data download thread signaled to stop. | 2020-09-25 22:57:16.847 HD Request # 20 | Received 1 record from 2020-09-25 21:59:03.242 to 2020-09-25 21:59:03.242 (0.0 seconds) and wrote 0 records for GBPUSD | 2020-09-25 22:57:16.847 HD Request # 20 | Completion time: 0s | 2020-09-25 22:57:16.848 HD Request # 20 | Intraday data download complete for GBPUSD. Unique request ID: 2 | 2020-09-25 22:57:16.848 Removing historical data download ID 2. | 2020-09-25 22:57:16.848 Real-time Intraday chart data file updates started for GBPUSD | 2020-09-25 22:57:16.848 Intraday chart data file opened for GBPUSD | 2020-09-25 22:57:16.848 HD Request # 20 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:16.848 Triggering next historical data download in queue. | 2020-09-25 22:57:16.848 HD Request # 21 | Downloading Intraday chart data for SPX500 to the file SPX500.scid. Service: fxcm | 2020-09-25 22:57:16.848 HD Request # 21 | Download start date-time: 2020-09-25 21:14:59.000 | 2020-09-25 22:57:16.848 HD Request # 21 | Using server: ds4.sierracharts.com port 10150 | 2020-09-25 22:57:16.848 Socket (1) | Creating socket. | 2020-09-25 22:57:16.848 Socket (1) | Connecting to IP: 192.81.56.146. | 2020-09-25 22:57:16.848 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:16.849 * Socket (3) | Socket gracefully closed by remote side. | 2020-09-25 22:57:16.937 Socket (3) | Closed. | 2020-09-25 22:57:16.937 HD Request # 21 | Setting DTC encoding to Binary VLS | 2020-09-25 22:57:17.094 HD Request # 21 | Sending historical data logon request message. | 2020-09-25 22:57:17.094 JP10YY1 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:17.257 Chart #3 has tagged chart #6 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:17.259 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:17.260 * EURJPY[M] 15 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:17.260 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:17.270 * DE10YY1 1 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:17.270 Chart #5 has tagged chart #1 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:17.278 Chart #5 has tagged chart #6 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:17.278 EURJPY[M] 30 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:17.280 EURJPY[M] 5 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:17.567 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:17.611 * JPN225[M] 1 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:17.613 Chart #9 has tagged chart #1 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:17.619 Circular chart reference detected. Charts: 10, 9. Chartbook: SEAN EJ Sam.Cht. | 2020-09-25 22:57:17.619 Chart #9 has tagged chart #6 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:17.619 EURJPY[M] 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:17.622 HD Request # 21 | Requesting Intraday data. Start date-time: 2020-09-25 21:14:59. Record interval: 0. Symbol: SPX500 | 2020-09-25 22:57:17.649 HD Request # 21 | Decompressing data. | 2020-09-25 22:57:17.756 HD Request # 21 | Receiving Intraday data for SPX500 starting at 2020-09-25 21:14:59.645000 | 2020-09-25 22:57:17.757 Socket (1) | CloseSocket call. | 2020-09-25 22:57:17.757 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-25 22:57:17.757 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-09-25 22:57:17.757 Historical data download thread signaled to stop. | 2020-09-25 22:57:17.765 HD Request # 21 | Timestamp of first Intraday data file record written: 2020-09-25 21:14:59.645001 | 2020-09-25 22:57:17.765 HD Request # 21 | Received 1 record from 2020-09-25 21:14:59.645 to 2020-09-25 21:14:59.645 (0.0 seconds) and wrote 1 record for SPX500 | 2020-09-25 22:57:17.765 HD Request # 21 | Completion time: 1s | 2020-09-25 22:57:17.766 HD Request # 21 | Intraday data download complete for SPX500. Unique request ID: 7 | 2020-09-25 22:57:17.766 Removing historical data download ID 7. | 2020-09-25 22:57:17.766 Real-time Intraday chart data file updates started for SPX500 | 2020-09-25 22:57:17.766 Intraday chart data file opened for SPX500 | 2020-09-25 22:57:17.766 HD Request # 21 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:17.766 Triggering next historical data download in queue. | 2020-09-25 22:57:17.766 HD Request # 22 | Downloading Intraday chart data for UK100 to the file UK100.scid. Service: fxcm | 2020-09-25 22:57:17.766 HD Request # 22 | Download start date-time: 2020-09-25 20:59:57.000 | 2020-09-25 22:57:17.766 HD Request # 22 | Using server: ds12.sierracharts.com port 10149 | 2020-09-25 22:57:17.766 Socket (3) | Creating socket. | 2020-09-25 22:57:17.766 Socket (3) | Connecting to IP: 204.15.197.14. | 2020-09-25 22:57:17.766 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:17.771 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:17.778 * EURJPY[M] 15 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:17.778 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:17.788 * EURJPY[M] 30 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:17.789 Socket (1) | Socket gracefully closed by remote side. | 2020-09-25 22:57:17.865 Socket (1) | Closed. | 2020-09-25 22:57:17.865 HD Request # 22 | Setting DTC encoding to Binary VLS | 2020-09-25 22:57:18.004 HD Request # 22 | Sending historical data logon request message. | 2020-09-25 22:57:18.004 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:18.084 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:18.095 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:57:18.099 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:18.101 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:18.111 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:18.350 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:18.352 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:18.352 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:18.374 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:18.420 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:18.564 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:18.575 * HD Request # 22 | Requesting Intraday data. Start date-time: 2020-09-25 20:59:57. Record interval: 0. Symbol: UK100 | 2020-09-25 22:57:18.594 HD Request # 22 | Decompressing data. | 2020-09-25 22:57:18.708 HD Request # 22 | Receiving Intraday data for UK100 starting at 2020-09-25 20:59:57.640000 | 2020-09-25 22:57:18.708 Socket (3) | CloseSocket call. | 2020-09-25 22:57:18.708 Socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-25 22:57:18.708 Socket (3) | Shutdown started. Waiting for graceful close. | 2020-09-25 22:57:18.709 Socket (3) | Socket gracefully closed by remote side. | 2020-09-25 22:57:18.816 Socket (3) | Closed. | 2020-09-25 22:57:18.816 Historical data download thread signaled to stop. | 2020-09-25 22:57:18.853 HD Request # 22 | Timestamp of first Intraday data file record written: 2020-09-25 20:59:57.719001 | 2020-09-25 22:57:18.853 HD Request # 22 | Received 2 records from 2020-09-25 20:59:57.640 to 2020-09-25 20:59:57.719 (0.1 seconds) and wrote 1 record for UK100 | 2020-09-25 22:57:18.853 HD Request # 22 | Completion time: 1s | 2020-09-25 22:57:18.854 HD Request # 22 | Intraday data download complete for UK100. Unique request ID: 8 | 2020-09-25 22:57:18.854 Removing historical data download ID 8. | 2020-09-25 22:57:18.854 Real-time Intraday chart data file updates started for UK100 | 2020-09-25 22:57:18.854 Intraday chart data file opened for UK100 | 2020-09-25 22:57:18.854 HD Request # 22 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:18.854 Triggering next historical data download in queue. | 2020-09-25 22:57:18.854 HD Request # 23 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc | 2020-09-25 22:57:18.854 HD Request # 23 | Download start date-time: 2020-09-25 21:59:09.000 | 2020-09-25 22:57:18.854 HD Request # 23 | Using server: ds3.sierracharts.com port 10150 | 2020-09-25 22:57:18.854 Socket (1) | Creating socket. | 2020-09-25 22:57:18.854 Socket (1) | Connecting to IP: 65.182.172.42. | 2020-09-25 22:57:18.854 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:18.855 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:18.867 * Chart #10 has tagged chart #9 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:18.872 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:18.873 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:18.883 * HD Request # 23 | Setting DTC encoding to Binary VLS | 2020-09-25 22:57:19.054 HD Request # 23 | Sending historical data logon request message. | 2020-09-25 22:57:19.054 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:19.119 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:19.133 * HD Request # 23 | Requesting Intraday data. Start date-time: 2020-09-25 21:59:09. Record interval: 0. Symbol: USDX | 2020-09-25 22:57:19.149 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:19.182 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:19.192 * HD Request # 23 | Decompressing data. | 2020-09-25 22:57:19.238 HD Request # 23 | Receiving Intraday data for USDX starting at 2020-09-25 21:59:09.000000 | 2020-09-25 22:57:19.238 Socket (1) | CloseSocket call. | 2020-09-25 22:57:19.239 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-25 22:57:19.239 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-09-25 22:57:19.239 Socket (1) | Socket gracefully closed by remote side. | 2020-09-25 22:57:19.328 Socket (1) | Closed. | 2020-09-25 22:57:19.328 Historical data download thread signaled to stop. | 2020-09-25 22:57:19.430 HD Request # 23 | Timestamp of first Intraday data file record written: 2020-09-25 21:59:09.000001 | 2020-09-25 22:57:19.430 HD Request # 23 | Received 1 record from 2020-09-25 21:59:09.000 to 2020-09-25 21:59:09.000 (0.0 seconds) and wrote 1 record for USDX | 2020-09-25 22:57:19.431 HD Request # 23 | Completion time: 1s | 2020-09-25 22:57:19.431 HD Request # 23 | Intraday data download complete for USDX. Unique request ID: 9 | 2020-09-25 22:57:19.431 Removing historical data download ID 9. | 2020-09-25 22:57:19.431 Real-time Intraday chart data file updates started for USDX | 2020-09-25 22:57:19.431 Intraday chart data file opened for USDX | 2020-09-25 22:57:19.431 HD Request # 23 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:19.431 Triggering next historical data download in queue. | 2020-09-25 22:57:19.431 HD Request # 24 | Downloading Intraday chart data for USDJPY to the file USDJPY.scid. Service: fxcm | 2020-09-25 22:57:19.431 HD Request # 24 | Download start date-time: 2020-09-25 21:59:06.000 | 2020-09-25 22:57:19.432 HD Request # 24 | Using server: ds4.sierracharts.com port 10149 | 2020-09-25 22:57:19.432 Socket (1) | Creating socket. | 2020-09-25 22:57:19.432 Socket (1) | Connecting to IP: 192.81.56.146. | 2020-09-25 22:57:19.432 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:19.436 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:19.447 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:19.498 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:19.508 * HD Request # 24 | Setting DTC encoding to Binary VLS | 2020-09-25 22:57:19.665 HD Request # 24 | Sending historical data logon request message. | 2020-09-25 22:57:19.665 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:19.759 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:19.770 * HD Request # 24 | Requesting Intraday data. Start date-time: 2020-09-25 21:59:06. Record interval: 0. Symbol: USDJPY | 2020-09-25 22:57:19.772 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:19.811 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:19.822 * HD Request # 24 | Decompressing data. | 2020-09-25 22:57:19.879 HD Request # 24 | Receiving Intraday data for USDJPY starting at 2020-09-25 21:59:06.902000 | 2020-09-25 22:57:19.879 Socket (1) | CloseSocket call. | 2020-09-25 22:57:19.880 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-25 22:57:19.880 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-09-25 22:57:19.880 Socket (1) | Socket gracefully closed by remote side. | 2020-09-25 22:57:19.998 Socket (1) | Closed. | 2020-09-25 22:57:19.998 Historical data download thread signaled to stop. | 2020-09-25 22:57:20.071 HD Request # 24 | Timestamp of first Intraday data file record written: 2020-09-25 21:59:06.902001 | 2020-09-25 22:57:20.071 HD Request # 24 | Received 1 record from 2020-09-25 21:59:06.902 to 2020-09-25 21:59:06.902 (0.0 seconds) and wrote 1 record for USDJPY | 2020-09-25 22:57:20.071 HD Request # 24 | Completion time: 1s | 2020-09-25 22:57:20.072 HD Request # 24 | Intraday data download complete for USDJPY. Unique request ID: 10 | 2020-09-25 22:57:20.072 Removing historical data download ID 10. | 2020-09-25 22:57:20.072 Real-time Intraday chart data file updates started for USDJPY | 2020-09-25 22:57:20.072 Intraday chart data file opened for USDJPY | 2020-09-25 22:57:20.072 HD Request # 24 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:20.072 Triggering next historical data download in queue. | 2020-09-25 22:57:20.072 HD Request # 25 | Downloading Intraday chart data for GER30 to the file GER30.scid. Service: fxcm | 2020-09-25 22:57:20.072 HD Request # 25 | Download start date-time: 2020-09-25 20:59:57.000 | 2020-09-25 22:57:20.072 HD Request # 25 | Using server: ds12.sierracharts.com port 10150 | 2020-09-25 22:57:20.072 Socket (1) | Creating socket. | 2020-09-25 22:57:20.072 Socket (1) | Connecting to IP: 204.15.197.14. | 2020-09-25 22:57:20.072 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:20.077 * Chart #12 has tagged chart #7 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:20.083 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:20.088 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:20.120 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:20.131 * HD Request # 25 | Setting DTC encoding to Binary VLS | 2020-09-25 22:57:20.297 HD Request # 25 | Sending historical data logon request message. | 2020-09-25 22:57:20.297 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:20.381 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:20.397 * HD Request # 25 | Requesting Intraday data. Start date-time: 2020-09-25 20:59:57. Record interval: 0. Symbol: GER30 | 2020-09-25 22:57:20.409 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:20.438 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:20.451 * HD Request # 25 | Decompressing data. | 2020-09-25 22:57:20.519 HD Request # 25 | Receiving Intraday data for GER30 starting at 2020-09-25 20:59:57.435000 | 2020-09-25 22:57:20.519 Socket (1) | CloseSocket call. | 2020-09-25 22:57:20.519 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-25 22:57:20.519 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-09-25 22:57:20.519 Socket (1) | Socket gracefully closed by remote side. | 2020-09-25 22:57:20.628 Socket (1) | Closed. | 2020-09-25 22:57:20.628 Historical data download thread signaled to stop. | 2020-09-25 22:57:20.728 HD Request # 25 | Timestamp of first Intraday data file record written: 2020-09-25 20:59:57.435001 | 2020-09-25 22:57:20.728 HD Request # 25 | Received 1 record from 2020-09-25 20:59:57.435 to 2020-09-25 20:59:57.435 (0.0 seconds) and wrote 1 record for GER30 | 2020-09-25 22:57:20.728 HD Request # 25 | Completion time: 0s | 2020-09-25 22:57:20.728 HD Request # 25 | Intraday data download complete for GER30. Unique request ID: 13 | 2020-09-25 22:57:20.728 Removing historical data download ID 13. | 2020-09-25 22:57:20.728 Real-time Intraday chart data file updates started for GER30 | 2020-09-25 22:57:20.728 Intraday chart data file opened for GER30 | 2020-09-25 22:57:20.728 HD Request # 25 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:20.728 Triggering next historical data download in queue. | 2020-09-25 22:57:20.728 HD Request # 26 | Downloading Intraday chart data for EURJPY to the file EURJPY.scid. Service: fxcm | 2020-09-25 22:57:20.729 HD Request # 26 | Download start date-time: 2020-09-25 21:59:08.000 | 2020-09-25 22:57:20.729 HD Request # 26 | Using server: ds3.sierracharts.com port 10149 | 2020-09-25 22:57:20.729 Socket (1) | Creating socket. | 2020-09-25 22:57:20.729 Socket (1) | Connecting to IP: 65.182.172.42. | 2020-09-25 22:57:20.729 HD Request # 26 | Setting DTC encoding to Binary VLS | 2020-09-25 22:57:20.914 HD Request # 26 | Sending historical data logon request message. | 2020-09-25 22:57:20.914 HD Request # 26 | Requesting Intraday data. Start date-time: 2020-09-25 21:59:08. Record interval: 0. Symbol: EURJPY | 2020-09-25 22:57:21.001 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:21.043 * Chart #10 has tagged chart #9 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:21.045 Chart #10 has tagged chart #9 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:21.050 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:21.054 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:21.056 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:21.068 * HD Request # 26 | Decompressing data. | 2020-09-25 22:57:21.108 HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:57:21.352 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:21.353 * JPN225[M] 1 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:21.356 Chart #9 has tagged chart #1 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:21.361 Circular chart reference detected. Charts: 10, 9. Chartbook: SEAN EJ Sam.Cht. | 2020-09-25 22:57:21.361 Chart #9 has tagged chart #6 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:21.361 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:21.370 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:21.373 * EURJPY[M] 15 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:21.373 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:21.384 * EURJPY[M] 30 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:21.385 HD Request # 26 | Receiving Intraday data for EURJPY starting at 2020-09-25 20:59:08.028000 | 2020-09-25 22:57:21.397 Socket (1) | CloseSocket call. | 2020-09-25 22:57:21.403 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-25 22:57:21.403 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-09-25 22:57:21.403 Socket (1) | Socket gracefully closed by remote side. | 2020-09-25 22:57:21.493 Socket (1) | Closed. | 2020-09-25 22:57:21.493 Historical data download thread signaled to stop. | 2020-09-25 22:57:21.706 HD Request # 26 | Received 6595 records from 2020-09-25 20:59:08.028 to 2020-09-25 21:59:07.854 (60.0 minutes) and wrote 0 records for EURJPY | 2020-09-25 22:57:21.706 HD Request # 26 | Completion time: 1s | 2020-09-25 22:57:21.706 HD Request # 26 | Intraday data download complete for EURJPY. Unique request ID: 14 | 2020-09-25 22:57:21.706 Removing historical data download ID 14. | 2020-09-25 22:57:21.706 Real-time Intraday chart data file updates started for EURJPY | 2020-09-25 22:57:21.706 Intraday chart data file opened for EURJPY | 2020-09-25 22:57:21.706 HD Request # 26 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:21.706 Triggering next historical data download in queue. | 2020-09-25 22:57:21.706 HD Request # 27 | Downloading Intraday chart data for USD-X to the file USD-X.scid. Service: fxstatscalc | 2020-09-25 22:57:21.706 HD Request # 27 | Download start date-time: 2020-09-25 21:59:12.000 | 2020-09-25 22:57:21.706 HD Request # 27 | Using server: ds4.sierracharts.com port 10150 | 2020-09-25 22:57:21.706 Socket (1) | Creating socket. | 2020-09-25 22:57:21.706 Socket (1) | Connecting to IP: 192.81.56.146. | 2020-09-25 22:57:21.707 HD Request # 27 | Setting DTC encoding to Binary VLS | 2020-09-25 22:57:21.919 HD Request # 27 | Sending historical data logon request message. | 2020-09-25 22:57:21.919 HD Request # 27 | Requesting Intraday data. Start date-time: 2020-09-25 21:59:12. Record interval: 0. Symbol: USD-X | 2020-09-25 22:57:22.018 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:22.054 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:22.100 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:22.103 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:22.114 * HD Request # 27 | Decompressing data. | 2020-09-25 22:57:22.118 HD Request # 27 | Receiving Intraday data for USD-X starting at 2020-09-25 21:59:12.000000 | 2020-09-25 22:57:22.118 Socket (1) | CloseSocket call. | 2020-09-25 22:57:22.118 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-25 22:57:22.118 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-09-25 22:57:22.118 Socket (1) | Socket gracefully closed by remote side. | 2020-09-25 22:57:22.232 Socket (1) | Closed. | 2020-09-25 22:57:22.233 Historical data download thread signaled to stop. | 2020-09-25 22:57:22.387 HD Request # 27 | Timestamp of first Intraday data file record written: 2020-09-25 21:59:12.000001 | 2020-09-25 22:57:22.387 HD Request # 27 | Received 1 record from 2020-09-25 21:59:12.000 to 2020-09-25 21:59:12.000 (0.0 seconds) and wrote 1 record for USD-X | 2020-09-25 22:57:22.387 HD Request # 27 | Completion time: 1s | 2020-09-25 22:57:22.388 HD Request # 27 | Intraday data download complete for USD-X. Unique request ID: 18 | 2020-09-25 22:57:22.388 Removing historical data download ID 18. | 2020-09-25 22:57:22.388 Real-time Intraday chart data file updates started for USD-X | 2020-09-25 22:57:22.388 Intraday chart data file opened for USD-X | 2020-09-25 22:57:22.388 HD Request # 27 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:22.388 Triggering next historical data download in queue. | 2020-09-25 22:57:22.388 HD Request # 28 | Downloading Intraday chart data for JPN225 to the file JPN225.scid. Service: fxcm | 2020-09-25 22:57:22.388 HD Request # 28 | Download start date-time: 2020-09-25 21:14:46.000 | 2020-09-25 22:57:22.388 HD Request # 28 | Using server: ds12.sierracharts.com port 10149 | 2020-09-25 22:57:22.388 Socket (1) | Creating socket. | 2020-09-25 22:57:22.388 Socket (1) | Connecting to IP: 204.15.197.14. | 2020-09-25 22:57:22.388 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:22.399 * Chart #11 has tagged chart #7 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:22.401 Chart #11 has tagged chart #8 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:22.401 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:22.412 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:22.414 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:22.424 * HD Request # 28 | Setting DTC encoding to Binary VLS | 2020-09-25 22:57:22.656 HD Request # 28 | Sending historical data logon request message. | 2020-09-25 22:57:22.656 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:22.662 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:22.676 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:22.678 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:22.690 * HD Request # 28 | Requesting Intraday data. Start date-time: 2020-09-25 21:14:46. Record interval: 0. Symbol: JPN225 | 2020-09-25 22:57:22.766 HD Request # 28 | Decompressing data. | 2020-09-25 22:57:22.875 HD Request # 28 | Receiving Intraday data for JPN225 starting at 2020-09-25 21:14:46.292000 | 2020-09-25 22:57:22.875 Socket (1) | CloseSocket call. | 2020-09-25 22:57:22.876 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-25 22:57:22.876 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-09-25 22:57:22.876 Historical data download thread signaled to stop. | 2020-09-25 22:57:22.944 HD Request # 28 | Timestamp of first Intraday data file record written: 2020-09-25 21:14:46.292001 | 2020-09-25 22:57:22.944 HD Request # 28 | Received 1 record from 2020-09-25 21:14:46.292 to 2020-09-25 21:14:46.292 (0.0 seconds) and wrote 1 record for JPN225 | 2020-09-25 22:57:22.944 HD Request # 28 | Completion time: 0s | 2020-09-25 22:57:22.944 HD Request # 28 | Intraday data download complete for JPN225. Unique request ID: 21 | 2020-09-25 22:57:22.944 Removing historical data download ID 21. | 2020-09-25 22:57:22.944 Real-time Intraday chart data file updates started for JPN225 | 2020-09-25 22:57:22.944 Intraday chart data file opened for JPN225 | 2020-09-25 22:57:22.944 HD Request # 28 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:22.944 Triggering next historical data download in queue. | 2020-09-25 22:57:22.944 HD Request # 29 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2020-09-25 22:57:22.945 HD Request # 29 | Download start date-time: 2020-09-25 21:44:59.000 | 2020-09-25 22:57:22.945 HD Request # 29 | Using server: ds3.sierracharts.com port 10150 | 2020-09-25 22:57:22.945 Socket (3) | Creating socket. | 2020-09-25 22:57:22.945 Socket (3) | Connecting to IP: 65.182.172.42. | 2020-09-25 22:57:22.945 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:22.955 * Chart #9 has tagged chart #1 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:22.958 Chart #9 has tagged chart #10 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:22.958 Chart #9 has tagged chart #6 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:22.958 GER30[M] 1 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:22.965 Circular chart reference detected. Charts: 9, 10. Chartbook: SEAN EJ Sam.Cht. | 2020-09-25 22:57:22.972 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:22.983 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:22.985 * EURJPY[M] 15 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:22.985 Socket (1) | Socket gracefully closed by remote side. | 2020-09-25 22:57:22.985 Socket (1) | Closed. | 2020-09-25 22:57:22.985 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:22.996 * EURJPY[M] 30 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:22.997 HD Request # 29 | Setting DTC encoding to Binary VLS | 2020-09-25 22:57:23.140 HD Request # 29 | Sending historical data logon request message. | 2020-09-25 22:57:23.140 HD Request # 29 | Requesting Intraday data. Start date-time: 2020-09-25 21:44:59. Record interval: 0. Symbol: USOil | 2020-09-25 22:57:23.236 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:23.260 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:23.272 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:23.274 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:23.289 * HD Request # 29 | Decompressing data. | 2020-09-25 22:57:23.324 HD Request # 29 | Receiving Intraday data for USOil starting at 2020-09-25 21:44:59.010000 | 2020-09-25 22:57:23.324 Socket (3) | CloseSocket call. | 2020-09-25 22:57:23.324 Socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-25 22:57:23.324 Socket (3) | Shutdown started. Waiting for graceful close. | 2020-09-25 22:57:23.324 Socket (3) | Socket gracefully closed by remote side. | 2020-09-25 22:57:23.423 Socket (3) | Closed. | 2020-09-25 22:57:23.423 Historical data download thread signaled to stop. | 2020-09-25 22:57:23.540 HD Request # 29 | Received 3 records from 2020-09-25 21:44:59.010 to 2020-09-25 21:44:59.525 (0.5 seconds) and wrote 0 records for USOil | 2020-09-25 22:57:23.540 HD Request # 29 | Completion time: 1s | 2020-09-25 22:57:23.540 HD Request # 29 | Intraday data download complete for USOil. Unique request ID: 22 | 2020-09-25 22:57:23.540 Removing historical data download ID 22. | 2020-09-25 22:57:23.540 Real-time Intraday chart data file updates started for USOil | 2020-09-25 22:57:23.540 Intraday chart data file opened for USOil | 2020-09-25 22:57:23.540 HD Request # 29 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:23.540 Triggering next historical data download in queue. | 2020-09-25 22:57:23.542 HD Request # 30 | Downloading Intraday chart data for USDOLLAR to the file USDOLLAR.scid. Service: fxcm | 2020-09-25 22:57:23.542 HD Request # 30 | Download start date-time: 2020-09-25 21:58:27.000 | 2020-09-25 22:57:23.542 HD Request # 30 | Using server: ds4.sierracharts.com port 10149 | 2020-09-25 22:57:23.542 Socket (1) | Creating socket. | 2020-09-25 22:57:23.542 Socket (1) | Connecting to IP: 192.81.56.146. | 2020-09-25 22:57:23.542 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:23.559 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:23.578 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:23.581 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:23.591 * HD Request # 30 | Setting DTC encoding to Binary VLS | 2020-09-25 22:57:23.753 HD Request # 30 | Sending historical data logon request message. | 2020-09-25 22:57:23.753 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:23.851 * HD Request # 30 | Requesting Intraday data. Start date-time: 2020-09-25 21:58:27. Record interval: 0. Symbol: USDOLLAR | 2020-09-25 22:57:23.864 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:23.865 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:57:23.870 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:23.870 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:23.881 * HD Request # 30 | Decompressing data. | 2020-09-25 22:57:23.963 HD Request # 30 | Receiving Intraday data for USDOLLAR starting at 2020-09-25 21:58:27.077000 | 2020-09-25 22:57:23.964 Socket (1) | CloseSocket call. | 2020-09-25 22:57:23.964 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-25 22:57:23.964 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-09-25 22:57:23.964 Socket (1) | Socket gracefully closed by remote side. | 2020-09-25 22:57:24.064 Socket (1) | Closed. | 2020-09-25 22:57:24.064 Historical data download thread signaled to stop. | 2020-09-25 22:57:24.134 HD Request # 30 | Timestamp of first Intraday data file record written: 2020-09-25 21:58:27.784001 | 2020-09-25 22:57:24.134 HD Request # 30 | Received 2 records from 2020-09-25 21:58:27.077 to 2020-09-25 21:58:27.784 (0.7 seconds) and wrote 1 record for USDOLLAR | 2020-09-25 22:57:24.134 HD Request # 30 | Completion time: 1s | 2020-09-25 22:57:24.135 HD Request # 30 | Intraday data download complete for USDOLLAR. Unique request ID: 23 | 2020-09-25 22:57:24.135 Removing historical data download ID 23. | 2020-09-25 22:57:24.135 Real-time Intraday chart data file updates started for USDOLLAR | 2020-09-25 22:57:24.135 Intraday chart data file opened for USDOLLAR | 2020-09-25 22:57:24.135 HD Request # 30 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:24.135 Triggering next historical data download in queue. | 2020-09-25 22:57:24.135 HD Request # 31 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2020-09-25 22:57:24.135 HD Request # 31 | Download start date-time: 2020-09-25 21:56:57.000 | 2020-09-25 22:57:24.135 HD Request # 31 | Using server: ds12.sierracharts.com port 10150 | 2020-09-25 22:57:24.135 Socket (1) | Creating socket. | 2020-09-25 22:57:24.135 Socket (1) | Connecting to IP: 204.15.197.14. | 2020-09-25 22:57:24.135 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:24.144 * Chart #13 has tagged chart #6 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:24.150 Chart #13 has tagged chart #7 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:24.150 Chart #13 has tagged chart #8 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:24.150 EURJPY[M] 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:24.164 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:24.332 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:24.334 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:24.344 * EURJPY[M] 30 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:24.345 HD Request # 31 | Setting DTC encoding to Binary VLS | 2020-09-25 22:57:24.385 HD Request # 31 | Sending historical data logon request message. | 2020-09-25 22:57:24.385 HD Request # 31 | Requesting Intraday data. Start date-time: 2020-09-25 21:56:57. Record interval: 0. Symbol: AUDJPY | 2020-09-25 22:57:24.497 HD Request # 31 | Decompressing data. | 2020-09-25 22:57:24.606 HD Request # 31 | Receiving Intraday data for AUDJPY starting at 2020-09-25 21:56:57.281000 | 2020-09-25 22:57:24.606 Socket (1) | CloseSocket call. | 2020-09-25 22:57:24.606 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-25 22:57:24.606 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-09-25 22:57:24.606 Historical data download thread signaled to stop. | 2020-09-25 22:57:24.642 HD Request # 31 | Timestamp of first Intraday data file record written: 2020-09-25 21:56:57.281001 | 2020-09-25 22:57:24.642 HD Request # 31 | Received 1 record from 2020-09-25 21:56:57.281 to 2020-09-25 21:56:57.281 (0.0 seconds) and wrote 1 record for AUDJPY | 2020-09-25 22:57:24.642 HD Request # 31 | Completion time: 0s | 2020-09-25 22:57:24.643 HD Request # 31 | Intraday data download complete for AUDJPY. Unique request ID: 24 | 2020-09-25 22:57:24.643 Removing historical data download ID 24. | 2020-09-25 22:57:24.643 Real-time Intraday chart data file updates started for AUDJPY | 2020-09-25 22:57:24.643 Intraday chart data file opened for AUDJPY | 2020-09-25 22:57:24.643 HD Request # 31 | Enabling Intraday chart updating for symbol. | 2020-09-25 22:57:24.643 Triggering next historical data download in queue. | 2020-09-25 22:57:24.643 EURJPY[M] 5 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:24.645 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:24.693 * Chart #14 has tagged chart #8 for full recalculation. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:24.706 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:24.708 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:24.710 * Socket (1) | Socket gracefully closed by remote side. | 2020-09-25 22:57:24.722 Socket (1) | Closed. | 2020-09-25 22:57:24.722 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:24.722 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:25.002 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:25.002 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:25.004 * EURJPY[M] 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EJ Sam.Cht | 2020-09-25 22:57:25.012 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:25.160 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:25.162 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:25.177 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:25.449 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:25.462 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:25.467 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:25.479 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:25.768 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:25.782 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:25.784 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:25.795 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:26.090 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:26.101 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:26.103 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:26.116 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:26.418 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:26.429 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:26.435 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:26.445 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:27.018 * EURUSD[M] 5 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.019 EURUSD[M] 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.048 SPX500[M] 1 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.114 Chart #9 has tagged chart #6 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.120 USD-X[M] 1 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.120 Chart #11 has tagged chart #6 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.153 Chart #11 has tagged chart #7 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.153 Chart #11 has tagged chart #8 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.153 EURUSD[M] 15 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.153 GER30[M] 1 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.155 Circular chart reference detected. Charts: 9, 10. Chartbook: SEAN EU Sam.Cht. | 2020-09-25 22:57:27.160 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:27.168 * US10YY1 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.168 Chart #3 has tagged chart #1 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.171 Chart #3 has tagged chart #6 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.171 Chart #3 has tagged chart #7 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.171 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:27.173 * DE10YY1 1 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.173 Chart #5 has tagged chart #1 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.178 Chart #5 has tagged chart #6 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.178 Chart #5 has tagged chart #7 for full recalculation. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.178 EURUSD[M] 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.178 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:27.236 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:57:27.469 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:27.470 * EURUSD[M] 5 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.471 EURUSD[M] 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.500 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:27.576 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:27.581 * EURUSD[M] 15 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: SEAN EU Sam.Cht | 2020-09-25 22:57:27.582 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:27.594 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:27.624 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:27.636 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:27.890 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:27.902 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:27.940 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:27.957 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:28.215 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:28.228 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:28.239 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:28.394 * GBPUSD[M] 15 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:28.635 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:28.637 * US10YY1 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:28.637 Chart #3 has tagged chart #1 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:28.639 Chart #3 has tagged chart #6 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:28.639 GB10YY1 1 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:28.641 Chart #5 has tagged chart #1 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:28.646 Chart #5 has tagged chart #6 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:28.646 GBPUSD[M] 30 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:28.651 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:28.794 * GBPUSD[M] 5 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:28.795 SPX500[M] 5 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:28.824 Chart #9 has tagged chart #1 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:28.825 Chart #9 has tagged chart #6 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:28.825 GBPUSD[M] 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:28.825 UK100[M] 5 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:28.863 Circular chart reference detected. Charts: 9, 10. Chartbook: SEAN GB Sam.Cht. | 2020-09-25 22:57:28.864 USDX[M] 1 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:28.864 Chart #11 has tagged chart #1 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:28.982 Chart #11 has tagged chart #8 for full recalculation. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:28.982 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:28.987 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:29.001 * GBPUSD[M] 15 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:29.224 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:29.226 * GBPUSD[M] 30 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:29.233 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:29.388 * GBPUSD[M] 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: SEAN GB Sam.Cht | 2020-09-25 22:57:29.389 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:29.427 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:29.442 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:29.668 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:29.694 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:29.708 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:29.946 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:29.951 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:29.952 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:57:29.952 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:29.954 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:30.009 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:30.126 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:30.140 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:30.372 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:30.400 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:30.430 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:30.444 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:30.679 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:30.707 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:30.750 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:30.764 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:30.997 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:31.025 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:31.053 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:31.068 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:31.304 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:31.333 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:31.371 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:31.385 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:31.618 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:31.647 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:31.689 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:31.704 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:31.942 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:31.970 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:31.993 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:32.007 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:32.231 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:32.259 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:32.314 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:32.328 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:32.563 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:32.592 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:32.614 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:32.629 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:32.866 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:32.895 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:57:32.899 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:32.934 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:32.949 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:33.176 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:33.205 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:33.238 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:33.252 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:33.493 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:33.521 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:33.556 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:33.570 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:33.803 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:33.832 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:33.874 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:33.888 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:34.121 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:34.150 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:34.176 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:34.190 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:34.429 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:34.457 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:34.491 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:34.505 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:34.746 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:34.774 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:34.814 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:34.828 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:35.053 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:35.081 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:35.127 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:35.141 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:35.380 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:35.408 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:35.431 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:35.445 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:35.681 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:35.709 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:35.748 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:35.762 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:57:36.001 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:36.003 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:36.032 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:36.062 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:36.076 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:36.311 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:36.339 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:36.366 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:36.381 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:36.613 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:36.641 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:36.684 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:36.699 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:36.930 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:36.958 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:37.002 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:37.017 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:37.245 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:37.274 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:37.310 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:37.324 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:37.549 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:37.577 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:37.625 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:37.640 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:37.877 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:37.906 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:37.925 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:37.940 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:38.180 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:38.209 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:38.241 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:38.255 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:38.507 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:38.536 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:38.561 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:38.575 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:38.831 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:38.859 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:57:38.864 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:38.865 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:38.879 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:39.122 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:39.152 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:39.182 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:39.197 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:39.449 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:39.478 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:39.502 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:39.517 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:39.769 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:39.797 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:39.810 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:39.824 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:40.078 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:40.106 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:40.124 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:40.138 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:40.407 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:40.439 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:40.441 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:40.455 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:40.701 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:40.730 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:40.741 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:40.756 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:41.020 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:41.049 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:41.059 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:41.073 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:41.346 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:41.375 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:41.380 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:41.394 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:41.644 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:41.672 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:41.681 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:41.695 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:41.959 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:57:41.960 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:41.989 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:41.999 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:42.014 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:42.277 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:42.305 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:42.311 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:42.326 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:42.580 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:42.608 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:42.622 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:42.636 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:42.916 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:42.950 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:42.952 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:42.966 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:43.198 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:43.228 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:43.242 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:43.256 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:43.532 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:43.561 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:43.563 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:43.577 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:43.847 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:43.876 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:43.881 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:43.896 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:44.136 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:44.164 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:44.183 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:44.198 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:44.467 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:44.495 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:44.497 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:44.511 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:44.765 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:44.793 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:44.811 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:44.825 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:57:44.854 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:45.075 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:45.104 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:45.127 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:45.141 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:45.405 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:45.437 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:45.439 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:45.453 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:45.729 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:45.757 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:45.759 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:45.773 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:46.056 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:46.085 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:46.088 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:46.106 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:46.371 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:46.400 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:46.405 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:46.420 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:46.659 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:46.687 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:46.690 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:46.704 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:46.985 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:47.014 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:47.016 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:47.030 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:47.285 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:47.314 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:47.320 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:47.335 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:47.604 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:47.633 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:47.635 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:47.649 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:47.906 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:47.938 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:57:47.938 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:47.940 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:47.954 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:48.222 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:48.250 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:48.253 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:48.267 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:48.547 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:48.575 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:48.577 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:48.591 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:48.850 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:48.878 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:48.884 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:48.898 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:49.161 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:49.189 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:49.191 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:49.206 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:49.482 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:49.510 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:49.516 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:49.531 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:49.795 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:49.823 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:49.829 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:49.844 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:50.085 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:50.114 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:50.136 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:50.150 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:50.418 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:50.451 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:50.456 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:50.470 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:50.719 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:50.748 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:50.757 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:50.772 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:57:51.045 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:51.047 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:51.075 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:51.077 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:51.092 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:51.360 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:51.388 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:51.394 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:51.408 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:51.659 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:51.687 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:51.695 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:51.709 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:51.972 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:52.001 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:52.013 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:52.027 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:52.292 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:52.321 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:52.329 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:52.343 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:52.615 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:52.644 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:52.645 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:52.663 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:52.919 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:52.955 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:52.957 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:52.971 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:53.230 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:53.259 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:53.264 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:53.280 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:53.560 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:53.588 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:53.591 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:53.605 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:53.839 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:53.868 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:57:53.873 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:53.886 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:53.900 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:54.156 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:54.185 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:54.201 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:54.216 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:54.479 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:54.509 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:54.511 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:54.528 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:54.783 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:54.812 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:54.825 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:54.844 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:55.105 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:55.135 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:55.142 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:55.156 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:55.434 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:55.465 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:55.467 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:55.482 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:55.722 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:55.752 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:55.768 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:55.783 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:56.044 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:56.072 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:56.080 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:56.094 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:56.361 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:56.389 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:56.394 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:56.409 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:56.678 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:56.707 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:56.709 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:56.723 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:57:56.972 Data file is currently being processed. Download not performed. | 2020-09-25 22:57:56.974 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:57.005 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:57.010 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:57.024 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:57.283 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:57.311 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:57.329 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:57.344 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:57.614 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:57.643 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:57.645 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:57.660 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:57.917 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:57.951 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:57.953 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:57.967 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:58.222 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:58.251 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:58.263 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:58.277 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:58.546 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:58.576 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:58.579 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:58.593 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:58.858 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:58.889 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:58.895 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:58.909 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:59.168 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:59.197 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:59.202 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:59.217 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:59.492 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:59.520 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:59.522 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:59.537 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:59.787 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:59.816 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:59.822 * Data file is currently being processed. Download not performed. | 2020-09-25 22:57:59.836 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:57:59.857 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:00.100 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:00.129 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:00.144 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:00.158 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:00.405 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:00.440 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:00.462 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:00.476 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:00.722 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:00.751 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:00.780 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:00.794 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:01.041 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:01.071 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:01.081 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:01.096 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:01.344 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:01.373 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:01.399 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:01.413 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:01.657 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:01.687 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:01.718 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:01.732 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:01.982 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:02.011 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:02.033 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:02.047 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:02.289 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:02.320 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:02.336 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:02.351 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:02.607 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:02.635 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:02.656 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:02.670 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:02.913 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:02.918 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:02.946 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:02.960 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:02.975 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:03.223 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:03.253 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:03.280 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:03.294 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:03.563 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:03.594 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:03.596 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:03.611 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:03.856 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:03.887 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:03.901 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:03.916 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:04.165 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:04.194 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:04.219 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:04.234 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:04.518 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:04.552 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:04.554 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:04.570 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:04.814 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:04.843 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:04.849 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:04.863 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:05.102 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:05.131 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:05.155 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:05.169 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:05.415 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:05.449 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:05.459 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:05.474 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:05.721 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:05.749 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:05.774 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:05.789 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:06.042 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:06.045 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:06.074 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:06.092 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:06.106 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:06.358 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:06.391 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:06.396 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:06.410 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:06.658 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:06.686 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:06.716 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:06.730 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:07.001 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:07.029 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:07.031 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:07.046 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:07.269 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:07.299 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:07.339 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:07.354 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:07.598 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:07.627 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:07.655 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:07.670 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:07.919 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:07.952 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:07.967 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:07.982 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:08.234 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:08.262 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:08.279 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:08.293 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:08.546 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:08.576 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:08.596 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:08.610 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:08.887 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:08.923 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:08.924 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:08.925 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:08.939 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:09.163 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:09.192 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:09.212 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:09.230 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:09.479 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:09.508 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:09.532 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:09.546 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:09.800 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:09.830 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:09.835 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:09.850 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:10.092 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:10.122 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:10.154 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:10.168 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:10.418 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:10.450 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:10.471 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:10.485 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:10.725 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:10.754 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:10.773 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:10.788 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:11.054 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:11.083 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:11.093 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:11.107 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:11.357 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:11.393 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:11.397 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:11.411 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:11.663 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:11.691 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:11.717 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:11.731 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:11.985 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:11.986 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:12.016 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:12.035 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:12.049 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:12.275 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:12.304 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:12.348 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:12.362 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:12.616 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:12.645 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:12.664 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:12.679 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:12.919 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:12.951 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:12.981 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:12.995 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:13.228 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:13.256 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:13.299 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:13.313 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:13.550 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:13.579 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:13.599 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:13.614 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:13.848 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:13.881 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:13.919 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:13.933 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:14.162 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:14.191 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:14.223 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:14.237 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:14.474 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:14.503 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:14.541 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:14.555 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:14.787 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:14.816 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:14.860 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:14.861 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:14.875 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:15.107 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:15.140 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:15.162 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:15.177 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:15.409 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:15.442 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:15.482 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:15.496 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:15.735 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:15.765 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:15.804 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:15.818 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:16.050 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:16.080 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:16.120 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:16.134 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:16.366 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:16.398 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:16.440 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:16.454 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:16.686 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:16.714 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:16.742 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:16.757 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:16.991 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:17.022 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:17.061 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:17.075 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:17.320 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:17.349 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:17.365 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:17.380 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:17.616 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:17.645 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:17.680 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:17.694 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:17.927 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:17.931 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:17.959 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:17.994 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:18.008 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:18.234 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:18.263 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:18.315 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:18.329 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:18.567 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:18.596 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:18.613 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:18.628 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:18.863 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:18.896 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:18.926 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:18.942 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:19.169 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:19.209 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:19.244 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:19.258 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:19.496 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:19.525 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:19.564 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:19.578 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:19.809 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:19.837 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:19.863 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:19.877 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:20.106 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:20.136 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:20.175 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:20.190 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:20.422 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:20.455 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:20.495 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:20.510 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:20.765 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:20.794 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:20.814 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:20.831 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:21.063 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:21.065 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:21.094 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:21.117 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:21.131 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:21.363 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:21.395 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:21.437 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:21.451 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:21.685 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:21.714 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:21.748 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:21.762 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:21.999 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:22.027 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:22.061 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:22.075 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:22.304 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:22.332 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:22.363 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:22.378 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:22.615 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:22.643 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:22.679 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:22.693 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:22.925 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:22.961 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:22.997 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:23.011 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:23.241 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:23.270 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:23.300 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:23.315 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:23.549 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:23.579 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:23.618 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:23.632 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:23.867 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:23.896 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:23.900 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:23.938 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:23.953 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:24.181 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:24.209 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:24.242 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:24.256 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:24.492 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:24.521 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:24.562 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:24.576 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:24.813 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:24.843 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:24.866 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:24.880 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:25.109 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:25.140 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:25.185 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:25.200 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:25.432 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:25.464 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:25.489 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:25.504 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:25.759 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:25.789 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:25.803 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:25.817 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:26.049 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:26.077 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:26.119 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:26.133 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:26.367 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:26.396 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:26.439 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:26.453 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:26.686 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:26.714 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:26.742 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:26.756 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:26.991 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:26.994 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:27.024 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:27.060 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:27.074 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:27.305 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:27.334 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:27.376 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:27.391 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:27.622 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:27.652 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:27.680 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:27.694 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:27.944 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:27.983 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:27.998 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:28.013 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:28.244 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:28.272 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:28.301 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:28.315 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:28.554 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:28.583 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:28.615 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:28.629 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:28.863 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:28.892 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:28.933 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:28.947 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:29.197 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:29.226 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:29.253 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:29.267 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:29.520 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:29.548 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:29.555 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:29.569 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:29.800 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:29.829 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:29.856 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:29.873 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:29.887 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:30.119 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:30.149 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:30.190 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:30.204 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:30.437 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:30.469 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:30.494 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:30.508 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:30.742 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:30.770 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:30.812 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:30.830 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:31.065 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:31.094 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:31.124 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:31.138 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:31.369 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:31.397 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:31.434 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:31.449 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:31.683 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:31.712 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:31.751 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:31.765 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:31.999 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:32.028 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:32.053 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:32.067 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:32.297 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:32.328 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:32.371 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:32.385 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:32.617 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:32.645 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:32.691 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:32.705 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:32.937 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:32.942 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:32.970 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:33.010 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:33.025 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:33.259 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:33.287 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:33.330 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:33.344 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:33.581 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:33.611 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:33.634 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:33.648 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:33.885 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:33.914 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:33.952 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:33.966 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:34.199 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:34.233 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:34.256 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:34.270 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:34.504 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:34.532 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:34.572 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:34.586 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:34.821 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:34.850 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:34.891 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:34.906 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:35.137 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:35.166 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:35.191 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:35.205 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:35.443 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:35.475 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:35.517 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:35.532 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:35.766 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:35.794 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:35.829 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:35.843 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:36.065 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:36.068 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:36.098 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:36.131 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:36.145 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:36.377 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:36.410 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:36.448 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:36.462 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:36.694 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:36.723 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:36.768 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:36.783 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:37.022 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:37.051 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:37.068 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:37.082 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:37.317 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:37.347 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:37.388 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:37.402 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:37.638 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:37.666 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:37.692 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:37.706 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:37.939 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:37.972 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:38.011 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:38.025 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:38.257 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:38.291 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:38.327 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:38.341 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:38.569 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:38.598 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:38.643 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:38.657 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:38.887 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:38.888 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:38.919 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:38.941 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:38.955 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:39.191 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:39.220 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:39.269 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:39.283 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:39.515 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:39.544 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:39.585 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:39.599 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:39.830 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:39.858 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:39.904 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:39.919 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:40.151 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:40.183 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:40.206 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:40.220 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:40.458 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:40.494 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:40.521 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:40.535 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:40.772 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:40.801 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:40.836 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:40.850 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:41.083 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:41.111 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:41.150 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:41.165 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:41.399 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:41.431 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:41.470 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:41.485 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:41.721 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:41.749 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:41.770 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:41.784 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:42.013 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:42.019 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:42.047 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:42.088 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:42.102 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:42.330 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:42.359 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:42.408 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:42.422 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:42.656 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:42.685 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:42.712 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:42.726 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:42.958 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:42.990 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:43.029 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:43.044 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:43.275 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:43.304 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:43.340 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:43.354 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:43.590 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:43.621 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:43.654 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:43.668 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:43.900 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:43.934 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:43.967 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:43.981 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:44.204 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:44.233 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:44.271 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:44.286 * HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2020-09-25 22:58:44.533 The message log has been sent to support. | 2020-09-25 22:58:44.533 * HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203. | 2020-09-25 22:58:44.533 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:44.557 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:44.588 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:44.590 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:44.605 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:44.855 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:44.884 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:44.885 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:44.899 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:44.915 * Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2020-09-25 22:58:45.174 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:45.177 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:45.209 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:45.219 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:45.236 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:45.487 * HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | CloseSocket call. | 2020-09-25 22:58:45.492 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-25 22:58:45.492 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-09-25 22:58:45.492 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-09-25 22:58:45.515 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-09-25 22:58:45.515 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:45.521 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:45.524 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:45.538 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:45.773 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:45.801 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:45.839 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:45.853 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:46.092 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:46.122 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:46.158 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:46.173 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:46.404 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:46.437 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:46.462 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:46.477 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:46.706 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:46.734 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:46.780 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:46.794 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:47.030 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:47.058 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:47.082 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:47.096 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:47.325 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:47.355 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:47.401 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:47.415 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:47.645 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:47.673 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:47.721 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:47.735 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:47.967 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:47.968 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:47.999 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:48.025 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:48.039 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:48.286 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:48.314 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:48.345 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:48.359 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:48.610 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:48.639 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:48.648 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:48.663 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:48.894 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:48.926 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:48.968 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:48.982 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:49.211 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:49.240 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:49.272 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:49.287 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:49.526 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:49.563 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:49.586 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:49.601 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:49.891 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:49.921 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:49.926 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:49.941 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:50.214 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:50.246 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:50.248 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:50.263 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:50.496 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:50.529 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:50.531 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:50.546 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:50.773 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:50.802 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:50.841 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:50.856 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:51.088 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:51.094 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:51.124 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:51.157 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:51.172 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:51.408 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:51.440 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:51.469 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:51.483 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:51.721 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:51.749 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:51.782 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:51.797 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:52.044 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:52.076 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:52.086 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:52.103 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:52.332 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:52.360 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:53.091 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:53.107 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:53.338 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:53.367 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:53.370 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:53.384 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:53.611 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:53.640 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:53.659 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:53.674 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:53.895 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:53.896 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:53.924 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:53.979 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:53.994 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:54.217 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:54.247 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:54.298 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:54.313 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:54.538 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:54.569 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:54.599 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:54.613 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:54.835 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:54.863 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:54.917 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:54.931 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:55.156 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:55.186 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:55.232 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:55.247 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:55.501 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:55.543 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:55.546 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:55.564 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:55.801 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:55.830 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:55.849 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:55.863 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:56.108 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:56.139 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:56.169 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:56.185 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:56.419 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:56.448 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:56.472 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:56.487 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:56.712 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:56.746 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:56.790 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:56.805 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:57.030 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:57.035 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:57.065 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:57.110 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:57.126 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:57.362 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:57.391 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:57.414 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:57.429 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:57.668 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:57.701 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:57.732 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:57.747 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:57.985 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:58.018 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:58.046 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:58.060 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:58.297 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:58.326 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:58.360 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:58.375 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:58.624 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:58.653 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:58.673 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:58.687 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:58.920 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:58.950 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:58.975 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:58.990 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:59.231 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:59.259 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:59.293 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:59.307 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:59.541 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:59.570 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:59.609 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:59.623 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:59.853 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:59.882 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:58:59.883 Data file is currently being processed. Download not performed. | 2020-09-25 22:58:59.913 * Data file is currently being processed. Download not performed. | 2020-09-25 22:58:59.927 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:00.160 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:00.197 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:00.230 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:00.244 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:00.481 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:00.515 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:00.548 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:00.563 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:00.796 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:00.826 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:00.850 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:00.864 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:01.102 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:01.132 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:01.170 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:01.187 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:01.420 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:01.454 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:01.474 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:01.488 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:01.726 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:01.755 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:01.791 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:01.806 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:02.034 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:02.063 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:02.109 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:02.124 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:02.349 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:02.377 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:02.411 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:02.425 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:02.662 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:02.691 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:02.731 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:02.745 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:02.980 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:59:02.981 Data file is currently being processed. Download not performed. | 2020-09-25 22:59:03.016 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:03.048 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:03.063 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:03.302 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:03.334 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:03.350 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:03.365 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:03.595 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:03.623 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:03.666 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:03.681 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:03.906 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:03.936 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:03.982 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:03.996 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:04.225 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:04.254 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:04.286 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:04.300 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:04.540 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:04.569 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:04.604 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:04.618 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:04.841 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:04.870 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:04.923 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:04.938 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:05.164 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:05.195 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:05.225 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:05.240 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:05.483 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:05.515 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:05.543 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:05.557 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:05.791 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:05.819 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:59:05.858 Data file is currently being processed. Download not performed. | 2020-09-25 22:59:05.859 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:05.874 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:06.105 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:06.135 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:06.161 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:06.175 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:06.411 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:06.442 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:06.480 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:06.495 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:06.734 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:06.763 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:06.798 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:06.813 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:07.047 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:07.077 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:07.102 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:07.117 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:07.345 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:07.376 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:07.422 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:07.437 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:07.665 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:07.694 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:07.726 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:07.741 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:07.976 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:08.009 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:08.043 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:08.058 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:08.290 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:08.320 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:08.359 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:08.374 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:08.610 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:08.639 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:08.675 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:08.689 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:08.912 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:59:08.913 Data file is currently being processed. Download not performed. | 2020-09-25 22:59:08.941 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:08.992 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:09.006 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:09.228 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:09.258 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:09.311 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:09.325 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:09.566 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:09.595 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:09.613 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:09.628 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:09.852 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:09.881 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:09.926 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:09.941 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:10.163 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:10.193 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:10.244 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:10.258 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:11.211 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:11.246 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:11.248 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:11.263 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:11.489 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:11.519 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:11.525 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:11.539 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:11.768 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:11.800 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:11.805 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:11.823 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:59:12.058 Data file is currently being processed. Download not performed. | 2020-09-25 22:59:12.064 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:12.093 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:12.125 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:12.139 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:12.370 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:12.399 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:12.437 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:12.451 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:12.690 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:12.720 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:12.739 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:12.753 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:12.980 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:13.013 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:13.056 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:13.071 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:13.314 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:13.345 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:13.374 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:13.388 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:13.618 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:13.648 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:13.678 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:13.692 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:13.917 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:13.946 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:14.005 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:14.023 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:14.288 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:14.322 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:14.330 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:14.345 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:14.578 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:14.608 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:14.616 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:14.631 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:14.858 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:14.892 * HD Request # 8 | Data processing progress: 0% - 0 records per second. | 2020-09-25 22:59:14.892 Data file is currently being processed. Download not performed. | 2020-09-25 22:59:14.931 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:14.945 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:15.166 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:15.195 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:15.249 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:15.263 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:15.492 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:15.524 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:15.553 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:15.567 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:15.819 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:15.853 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:15.871 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:15.885 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:16.114 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:16.143 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:16.188 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:16.202 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:16.430 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:16.458 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:16.488 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:16.503 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:16.728 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:16.757 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:16.808 * Data file is currently being processed. Download not performed. | 2020-09-25 22:59:16.823 * Date Time Of Last Edit: 2020-09-29 23:16:20
[2020-09-28 10:14:30] |
We are going to look into this today. It relates to custom calculated symbols. For now stop using symbols like this and restart Sierra Chart: HD Request # 8 | Downloading Intraday chart data for {DE10YY1}-{US10YY1} to the file {DE10YY1}-{US10YY1}.scid. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-29 23:34:59] |
There is something unusual you are doing regarding your custom data files and the custom calculated symbol. We cannot see how this message would be repetitively occurring. One thing though in the Global Symbol Settings the Historical Intraday Data Source, must be set to "Not Set" for the custom data file symbols and also the custom calculated symbol. If you have any idea what you are doing out of the ordinary which is causing the issue let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
