Date/Time: Tue, 11 Feb 2025 21:05:23 +0000
trade service log
View Count: 540
[2020-09-24 03:03:11] |
User863099 - Posts: 8 |
I have included a screen shot of this window that pops up every time I start green charts. It never use to be like this. Is there a fix for this? Is it a problem or normal? Thanks
[2020-09-24 03:47:05] |
Delete the data file being referenced in that message to prevent that message from showing up again. You can delete the file through Windows Explorer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
