Date/Time: Tue, 11 Feb 2025 21:34:46 +0000
Flatten button cancelled bracket but not position
View Count: 456
[2020-09-23 23:19:56] |
User198159 - Posts: 6 |
Hi There, I was trading the Micros today and when I wanted to get out of my position, I hit the flatten button but it only cancelled my bracket (Stop loss and take profit orders) but not my position. This happened two times today. Could you please check what the issue is. I don't want to have that again! Thank you! Kind regards, S |
[2020-09-24 14:40:45] |
Sierra_Chart Engineering - Posts: 18389 |
The reason for this is explained here along with a solution: Basic Trading and the Trade Window: Rejected Market Order When Using Flatten or Reverse Because of Position Limit Exceeded Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
