Date/Time: Sat, 31 Oct 2026 08:01:05 +0000
falla de conexión para poder ingresar a la plataforma
View Count: 942
[2020-09-23 21:18:41]
Oscartrader - Posts: 1
Cordial Saludo
el siguiente mensaje solicito por favor de su ayuda con el siguiente caso; abrí el día 23 de septiembre una cuenta demo, pero resulta que al momento de abrir la plataforma no me conecta y me sale un mensaje donde dice que mi nombre de usuario o contraseña son incorrectos y por ende se queda en estado rojo y no puedo ingresar a la plataforma.
agradecería mucho su colaboración con este tema ya que el tiempo para operar la plataforma es limitado en una cuenta demo, pues son solamente 15 días
Gracias
Quedo atento a sus comentarios
[2020-09-24 13:48:04]
From Google Translate:
Best regard
The following message please request your help with the following case; I opened a demo account on September 23, but it turns out that when I open the platform it does not connect me and I get a message saying that my username or password is incorrect and therefore it remains in red status and I cannot enter to the platform.
I would greatly appreciate your collaboration with this issue since the time to operate the platform is limited in a demo account, as it is only 15 days
Thank you
Stay tuned to your comments
It looks like you are trying to connect to CQG. Make sure you follow through the setup instructions located here:
CQG Trading Platform Service: Setup Instructions
If you continue to have a problem with the CQG Username/Password that you are entering, and you are certain that you are entering them properly, then you will need to talk to your broker about that issue, as there is a mismatch between what you are entering and what they have for your actual Username and Password.
