Date/Time: Tue, 11 Feb 2025 21:04:53 +0000
trend line sound alert
View Count: 792
[2020-09-23 20:04:40] |
Tonkadad - Posts: 235 |
How do I create a trend line sound alert when crossed. I would like to use the "Line" drawing tool.
[2020-09-23 20:18:25] |
John - SC Support - Posts: 37887 |
One option (and probably the easiest) is to use the Chart Drawing Alerts. Refer to the information here: Chart Drawing Tools: Chart Drawing Alerts Another is to use the Simple Alerts and reference the drawing in the alert. Refer to the information here generally for Simple Alerts: Study/Chart Alerts And Scanning And here specifically for how to reference a drawing in a simple alert: Study/Chart Alerts And Scanning: Referencing Chart Drawings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
