Date/Time: Mon, 25 Nov 2024 11:25:31 +0000
Alert Sounds
View Count: 1172
[2014-02-07 17:47:48] |
wingz - Posts: 121 |
I've set an alert on a few charts. The alert sounds .......1 thru whatever.......are all the same sound. Is there any documentation on how to change the alert sound to a different sound, so I can have the three alerts each make a different sound when they trigger? I can't seem to find it.
[2014-02-07 19:48:11] |
Refer to: http://www.sierrachart.com/index.php?l=doc/doc_GeneralSettings.html#AlertSoundSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
