Date/Time: Mon, 25 Nov 2024 11:23:17 +0000
SC, will you ever fix these graphics issues?
View Count: 1096
[2014-02-07 17:19:32]
abrown8703 - Posts: 64
SC, there are toolbar button issues. Please see attached image.
Thank You.
image2014-02-07_1214.png / V - Attached On 2014-02-07 17:19:09 UTC - Size: 111.1 KB - 413 views
[2014-02-07 18:23:48]
Eventually this will be solved . This requires a button which will automatically get wider based upon the length of the text. With the current ToolBar that is being used from Microsoft, it is not possible for the buttons have different sizes. They all must be the same size.
