Date/Time: Tue, 11 Feb 2025 21:06:01 +0000
Spreadsheet doubles timeframes after reload
View Count: 475
[2020-09-23 08:51:10] |
User571067 - Posts: 6 |
I recently discovered an issue i've been having with spreadsheet. When I open a spreadsheet for trading, starting from that point, when a new candle is started, the previous candle doubles. See screenshot for explanation. This doubles the bars I have on my chart. Is there a problem in my settings or is this a software issue? Chartbook and spreadsheet added below. The fix is to reload at every candle, but that seems a bit over the top right? Kind regards |
Private File Private File Private File |
[2020-09-23 14:50:19] |
John - SC Support - Posts: 37887 |
The reason why you have the data being doubled is because you have two Spreadsheet Studies that are both writing to the same sheet. You cannot do this, or you get what you are seeing. Refer to the information in this section: Spreadsheet Study Inputs: Chart Data Output Sheet Number For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
