Date/Time: Mon, 25 Nov 2024 12:39:48 +0000
ACSIL - round() function
View Count: 2063
[2014-02-07 16:21:15]
ejtrader - Posts: 688
SC Team - In order to generate an integer from Price to use it as an unique Linenumber for tool using the below function.
Tool.LineNumber=round(sc.Close[sc.Index]/sc.TickSize);
This round function works with gcc but not with MS compiler. Wondering if you are aware of an equivalent round function in MS or if there is any better alternative to achieve the above result - which can be used for any type of instrument. Basically want to derive the line number from the price itself.
Any suggestions?
Date Time Of Last Edit: 2014-02-07 20:47:01
[2014-02-07 20:45:20]
int sc.Round(float Number)
