Date/Time: Tue, 11 Feb 2025 21:01:29 +0000
Question
View Count: 495
[2020-09-23 01:34:05] |
User982388 - Posts: 11 |
If I have a 5 Minutes Chart, there are about 71 bars on the regular session from 9:30 to 4:00. Is there any study that I can use to draw a number on each bar ( on top or below ). So I can know at any time of day what bar we are in ? Example: 9:35 ------ 1 9:40 ------- 2 9:45 -------- 3 9:50 ------- 4 4:00 ------- 71 Thanks |
[2020-09-23 07:34:51] |
Have a look at this study: Bar Numbering Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
