Date/Time: Tue, 11 Feb 2025 21:29:28 +0000
SCID format changed?
View Count: 620
[2020-09-22 22:21:36] |
CBR600RR - Posts: 37 |
According to Intraday Data File Format the datetime is a double. Is this still the case? Parsing it as a double yields strange numbers. If I parse it as long I get values like 3778430163000000 which seems to make more sense but what is that number relative to?
[2020-09-22 22:36:16] |
There is a change. We have to update the documentation. We are doing that now.
