Date/Time: Tue, 11 Feb 2025 20:52:21 +0000
orders
View Count: 494
[2020-09-22 16:26:28] |
User318521 - Posts: 47 |
hello, my orders do not match up with my chart window or order lines. is there a reset or fix for this thanks
[2020-09-22 19:04:20] |
Sierra_Chart Engineering - Posts: 18389 |
This is not clear for us. Could you provide us a screenshot and a more detailed explanation. You can attach an image of the chart following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
