Date/Time: Sat, 01 Mar 2025 11:00:45 +0000
Stacked imbalance highlight in Footprint
View Count: 5055
[2020-09-22 15:40:44]
Dazz - Posts: 12
Please can you someone assist me if possible! I'm trying to simply highlight imbalances >300% with also the volume profile displayed in the same column. Similar to pic 1.
the closest I can get is to have the VP in column 2. Pic 2 is my settings. I am playing with the % Threshold but the VP colour is also changing. I only want the text to highlight imbalances in blue/red and the VP to stay a constant colour.
What are the correct settings? thank you.
imagePic 1 Footprint-Volume-Profile.png / V - Attached On 2020-09-22 15:38:32 UTC - Size: 67.83 KB - 3057 views
imagePic 2 NB Settings.png / V - Attached On 2020-09-22 15:38:37 UTC - Size: 591.97 KB - 2162 views
[2020-09-22 15:50:36]
John - SC Support - Posts: 38292
Set the following:
- Column 1 Background Type: Volume Profile
- Column 1 Background Coloring Method: Based on Volume Actual
- Column 1 Background Colors: 128, 128, 128 (make them all the same as the Column 2 colors are now)
- Column 2 Background Coloring Method: None - Transparent
- Column 1 Percent Compare Thresholds: 0, 0, 3
- Use Separate Colors for Text Coloring Method: Yes
- Range 3 Up/Down Color for Text: Set these to what you want to stand out when the imbalance is greater than 300%
- Range 0/1/2 Up/Down Color for Text: Set these to a color you want to be different from the Range 3 colors (or the same as your background to not display at all).
[2020-09-22 19:01:59]
Dazz - Posts: 12
thank you
[2021-10-03 08:03:12]
Moodzy89 - Posts: 7
which is the part to change if you want to highlight 400% imbalance? How do i change the 300% imbalance to 400%?
Thank you
[2021-10-03 20:42:33]
Change the Percent Compare Thresholds to "0, 0, 4"
