Date/Time: Tue, 04 Mar 2025 06:32:06 +0000
display 2 chartbooks at the same time
View Count: 1833
[2020-09-22 14:39:55] |
User525965 - Posts: 153 |
Hi! I have a 2nd monitor, is it possible to display 2 chartbooks at the same time? 1 on my main monitor and 1 on a 2nd?
[2020-09-22 15:34:22] |
John - SC Support - Posts: 38341 |
The only way to actually have the full chartbook (and hence all of the chart tabs that go with it) on a separate monitor is to use a second instance of Sierra Chart and move that to the second monitor. Refer to the information here: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Instructions For Sharing Data Using Sub Instances (Easiest And Recommended Method) Otherwise, you can always move individual charts to the other monitor by detaching them from the main window. Refer to the information here: Detaching and Attaching Chart Windows: Detaching a Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-25 15:58:19] |
once I have created the 2nd instance. I can just go to file, new instance to open it every day?
[2021-11-29 15:23:36] |
You can automatically open additional instances when you start Sierra Chart. Refer to the following: General Settings Window: Instances to Run on Startup (Global Settings >> General Settings >> General >> New Instances) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
