Date/Time: Tue, 11 Feb 2025 21:13:12 +0000
SC crashes
View Count: 456
[2020-09-22 06:26:00] |
goodness - Posts: 8 |
Hi, SC is crashing when I am using an 3rd part indicator. Following window appears (attachemnt) and when click ok, SC crashes.
[2020-09-22 10:50:00] |
Refer to help topic 17: Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
