Date/Time: Thu, 13 Feb 2025 07:00:16 +0000
Issues with Replay chart
View Count: 611
[2020-09-21 21:00:37]
User198159 - Posts: 6
Hi there,
I have an issue using my replay chart. When I hit play "Replay all the charts with same link number", only the 10 tick chart is moving but my Footprint, DOM etc. is on pause. When I hit pause, only the 10 tick chart is moving. I have linked them all together and restarted Sierra 2 times but it doesn't work.
I would appreciate some help.
Thank you!
imageScreenshot sierra, only 10 tick chart is playing.png / V - Attached On 2020-09-21 20:59:20 UTC - Size: 314.66 KB - 204 views
imagescreenshot sierra 1, everything working except 10 tick chart.png / V - Attached On 2020-09-21 20:59:31 UTC - Size: 487.03 KB - 206 views
[2020-09-22 10:57:44]
Do they all have the same Chart Link Number?
The other thing is to make sure the Days to Load setting is identical for these charts and Trading DOMs:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DaysToLoad
Date Time Of Last Edit: 2020-09-22 10:57:49
[2020-11-27 17:18:18]
I fixed it, thank you very much. I apologize for my late response
