Date/Time: Tue, 11 Feb 2025 21:05:55 +0000
BTC futures contract missing data
View Count: 669
[2020-09-21 20:33:19] |
onnb - Posts: 662 |
Using SC Data All Services, historical BTC futures contracts seem to have a gap. I am getting historical bars up to August 6th and now on September 21 - all the days in between are missing. Do you know anything about this? |
[2020-09-22 10:54:08] |
What is the specific symbol you are referring to?
[2020-09-22 18:31:57] |
John - SC Support - Posts: 37887 |
We do not see any issues. Here is a BTCV20 Continuous chart with 100 days loaded: http://www.sierrachart.com/image.php?Image=1600799402529.png Make sure you do Delete All Data and Download and be sure to select all the contract months in order to redownload the data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-23 05:28:40
[2020-09-22 19:18:41] |
We found a problem with the symbol settings. Redownload the data in the chart by following these instructions (you need to update the symbol settings in Step #3, but you do not need to uncheck the option for "Use Custom Symbol Settings Values": Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
