Date/Time: Tue, 11 Feb 2025 20:44:37 +0000
Swing high low indicator like Larry Williams
View Count: 667
[2020-09-21 19:38:39] |
BBUser - Posts: 1 |
Dear support team, I'm looking for a modified swing high low indicator that fits the definition of Larry Williams (Long Term Secrets to Short Term Trading, chapter 1) for Swings. With the swing high low indicator in sierra charts, the swings are also shown as a swing if, for example, a swing high only has a lower high on both sides of the candle. But I only want to see individual swings if the low of the "swing candle" is broken (i.e. it is not an insidebar). A Swing would also be good if the Insidebar is followed by a candle that breaks the low without exceeding the high (in a Swing high). I don't want the constellations with an insidebar to be displayed as Swing high or low. I hope I have described my problem understandably. Is there a possibility that you implement this option as a choice in the swing high low indicator? Or do you know another indicator that can do this? Thanks a lot!
Date Time Of Last Edit: 2020-09-21 19:39:05
