Date/Time: Tue, 11 Feb 2025 21:24:58 +0000
fast way to change all symbols of a CB
View Count: 506
[2020-09-21 10:08:27] |
AKR - Posts: 523 |
is there something like that? or to change the symbol of eg charts I choose simultaneousy? or is there no way around doing for each separately?
[2020-09-21 13:21:37] |
JohnR - User831573 - Posts: 309 |
This is the way to link multiple charts. One of the possible links is symbol. When you change it on one chart all of the others linked to it change as well. Working With Charts: Chart Linking John |
[2020-09-22 10:38:20] |
Yes you need to use Chart Linking: Working With Charts: Chart Linking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
