Date/Time: Tue, 11 Feb 2025 20:20:16 +0000
Support in Data Feed
View Count: 463
[2020-09-21 05:47:43] |
User655286 - Posts: 1 |
I need to know how can I reduce de amount of my data feed pricing. I only need data for CME
[2020-09-21 16:18:44] |
John - SC Support - Posts: 37886 |
The only thing we can do is point you to the Denali Exchange Data Feed. In general it is $25.00 USD per month for the data feed itself and then you need to add the Exchange Fees. You can reduce the cost of the data feed if you are using the Sierra Chart Order Routing service, which drops the cost of the data feed to $20.00 USD per month. Refer to the information here: Denali Exchange Data Feed And note the exchange fees in the Supported Exchanges section in that page. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
