Date/Time: Tue, 11 Feb 2025 20:39:06 +0000
TAB key for keyboard shortcuts
View Count: 525
[2020-09-20 23:55:16] |
User629461 - Posts: 184 |
Hi, I noticed the TAB key is not in the dropdown list of keys for keyboard shortcuts. Can it be included? Would be beneficial to expand left-hand functionality. Searched for old posts on this topic but couldnt find any so apologies if it has been answered.
[2020-09-21 01:06:43] |
No because that would interfere with the use of the tab key in other areas of the program like settings windows.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-21 01:07:07
