Date/Time: Mon, 05 Oct 2026 18:01:17 +0000
[Programming Help] - CMake and Including the Sierra Chart Header files?
View Count: 1911
| [2020-09-20 22:14:28] |
| mbilyanov - Posts: 62 |
Hi, I have successfully built a DLL under Linux following instructions on this board. Now I'm trying to re-create the same process but using CMake. I got bits and pieces to work (toolchain file, mingw32 etc.), however, I was not able to add the `ACS_Source` file to the include directories. Has anyone successfully built a SC Custom Study DLL using CMake? Basically this command works: /usr/bin/x86_64-w64-mingw32-g++ -march=x86-64 -mtune=x86-64 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -I /home/me/.wine/drive_c/SierraChartLinux/ACS_Source/ -w ./src/MySCStudy.cpp -o ./build/MySCStudy.dll
But inside my CMakeLists, I was not able to specify the include directory for some reason. Any ideas? |
| [2020-09-21 08:21:53] |
This is my CMake file so far: # ;-------------------------------------------------------------------------------- # ; Initials # ;-------------------------------------------------------------------------------- cmake_minimum_required(VERSION 3.1) project(MySCStudy) MESSAGE(STATUS "<${PROJECT_NAME}> CMAKE_BUILD_TYPE: ${CMAKE_BUILD_TYPE}") MESSAGE(STATUS "<${PROJECT_NAME}> CMAKE_BINARY_DIR: ${CMAKE_BINARY_DIR}") # ;-------------------------------------------------------------------------------- # ; Include Directories # ;-------------------------------------------------------------------------------- set(SC_INCLUDE_DIR /home/mbilyanov/.wine/drive_c/SierraChartLinux/ACS_Source) set(MINGW_INCLUDE_DIR /usr/x86_64-w64-mingw32/include) MESSAGE(STATUS "<${PROJECT_NAME}> SC_INCLUDE_DIR: ${SC_INCLUDE_DIR}") #MESSAGE(STATUS "<${PROJECT_NAME}> MINGW_INCLUDE_DIR: ${MINGW_INCLUDE_DIR}") # ;-------------------------------------------------------------------------------- # ; Compiler Flags # ;-------------------------------------------------------------------------------- set(CMAKE_CXX_FLAGS ${CMAKE_CXX_FLAGS} "-march=x86-64 -mtune=k8") add_compile_options(-O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions) # ;-------------------------------------------------------------------------------- # ; Source Files # ;-------------------------------------------------------------------------------- # file(GLOB SOURCE_FILES # "./src/*.cpp" # ) set(SOURCE_FILES ./src/MySCStudy.cpp) set(SC_HEADER_FILES ${SC_INCLUDE_DIR}/sierrachart.h) # ;-------------------------------------------------------------------------------- # ; Properties # ;-------------------------------------------------------------------------------- set(CMAKE_LIBRARY_OUTPUT_DIRECTORY ${CMAKE_BINARY_DIR}/${CMAKE_PROJECT_NAME}/${CMAKE_BUILD_TYPE}/lib) set(CMAKE_SHARED_LIBRARY_PREFIX "") add_library(${PROJECT_NAME} SHARED ${SOURCE_FILES} ${SC_HEADER_FILES}) target_include_directories(${PROJECT_NAME} PUBLIC ${SC_INCLUDE_DIR}) # ;-------------------------------------------------------------------------------- # ; Generate Compilation Database # ;-------------------------------------------------------------------------------- set(CMAKE_EXPORT_COMPILE_COMMANDS 1) ADD_CUSTOM_COMMAND(TARGET ${PROJECT_NAME} PRE_BUILD COMMAND ${CMAKE_COMMAND} -E copy ${CMAKE_BINARY_DIR}/compile_commands.json ${PROJECT_SOURCE_DIR} ) But I'm not getting any reference to the ACS_Sources location where the sierrachart headers are in the generated Makefile and when I build the dll, it is a malformed dll file reporting: CreateStudyDLLModuleFunctionObject | Error loading C:\SierraChartLinux\Data\MySCStudy.dll. Windows error code 126: Module not found. Likely missing dependency file. | 2020-09-21 08:18:59.845 * |
| [2020-09-21 21:07:59] |
Any ideas? I have been struggling with this for a while now. No matter what I tried I could not get CMake to include the Sierra Chart headers.
Date Time Of Last Edit: 2020-09-21 21:08:09
| [2020-09-24 13:36:01] |
| AlexPereira - Posts: 197 |
this is part of what i am using for my project: ( i have a symlink to the ACS_Sources dir on /home/alex/.sierracharts_source ) cmake_minimum_required(VERSION 3.13) SET(CMAKE_CXX_COMPILER "/usr/bin/x86_64-w64-mingw32-g++") project(ajp_study) SET(CMAKE_SYSTEM_NAME Win32) SET(CMAKE_CROSSCOMPILING 1) SET(CMAKE_SHARED_LIBRARY_LINK_C_FLAGS "-fno-exceptions -fpermissive") SET(CMAKE_SHARED_LIBRARY_LINK_CXX_FLAGS "-fno-exceptions -fpermissive") SET_PROPERTY(GLOBAL PROPERTY TARGET_SUPPORTS_SHARED_LIBS TRUE) SET(CMAKE_SHARED_LIBRARY_PREFIX "") MESSAGE( "64 bits compiler detected" ) SET(CMAKE_SYSTEM_PROCESSOR x86_64) SET(CMAKE_CXX_FLAGS "-march=x86-64 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -fpermissive -std=gnu++11") SET(CMAKE_SHARED_LIBRARY_SUFFIX "_64.dll") add_subdirectory(src) #subdirs(src) #gentoo linux target_include_directories(ajp_study PUBLIC /home/alex/.sierracharts_source /usr/x86_64-w64-mingw32/mingw/include/) #opensuse #target_include_directories(ajp_study PUBLIC /home/alex/.sierracharts_source /usr/x86_64-w64-mingw32/sys-root/x86_64-w64-mingw32/include) target_compile_options(ajp_study PUBLIC -fpermissive -Wno-deprecated -Wno-ignored-attributes -fms-extensions) install(TARGETS ajp_study RUNTIME DESTINATION "specified path to install XYZ" LIBRARY DESTINATION "specified path to install XYZ") |
| [2020-09-24 17:45:28] |
Thanks! I got my CMake setup working. It was quite difficult to figure that stuff up honestly :) Do you find that the DLLs you build with CMake are larger than the command line build or the Remote build? Also did you have to build a cmake toolchain file to make Cmake find the mingw compiler? Thank you very much for the help! Much appreciated. |
| [2020-09-27 19:30:50] |
yes, they are larger than when I build them on VS Also did you have to build a cmake toolchain file to make Cmake find the mingw compiler?
I just reference the mingw compiler and header files in the cmake. Apart from that, I don't see any differences between compiling on VS or mingw, in terms of instability. note: that I then reference the "src" subdirectory, and its in there that I add the source files ( which I didn't post :P ) |
| [2020-09-28 13:03:49] |
Thanks for the info, very helpful.
