Date/Time: Tue, 11 Feb 2025 20:26:55 +0000
Chart trading
View Count: 660
[2020-09-20 06:12:28] |
Tonkadad - Posts: 235 |
Is it possible to modify the size of the trade window besides the "C" button (compact). It still is vertically long.
[2020-09-20 10:22:33] |
No not at this time. We expect to be redeveloping that window completely at some point.
[2020-09-20 19:58:22] |
Is there anyway for a user to create their own trading interface so that trades/orders show up on chart and can be interactively adjusted on chart? IS there any code from the spreadsheet or ACSILL that will show on chart and can be adjusted. |
[2020-09-20 20:51:42] |
Yes this is already supported. Refer to: Chart Trading and the Chart DOM: Chart Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-20 21:53:12] |
Thank you. I know you can place orders on the chart with the chart trading panel, I would like to create my own trading interface, setup how I want, and send orders to my Broker but also be able to adjust on chart.
