Date/Time: Tue, 11 Feb 2025 20:46:50 +0000
hello!
View Count: 502
[2020-09-20 00:32:52] |
Mr.DaxF - Posts: 45 |
hello i used a Tradovate life account within CQG life! but i have seen some issues with my trade results therefore i ask it is possible to activated this: Sierra Chart Exchange Data Feed but i didnt can change the broker "tradovate" cause not exist on brokerlist! and i dont can breakup the activated process cause broker missing! can you assist me! background: my system make some issues i will check if it work bether when i used this setting! |
[2020-09-20 05:35:43] |
Did you want to use Sierra Chart provided real-time market data? If so for what exchanges?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-20 09:24:03
