Date/Time: Tue, 11 Feb 2025 20:22:49 +0000
Change symbol from chart problem
View Count: 523
[2020-09-19 20:53:39] |
anouar6869 - Posts: 13 |
Hi Support, On Version 2168 changing symbol from chart the tick value becomes that of the previous symbol. -Use custom symbol settings is checked. I also have v2115 and is fine. I don't know from what version after v2115 the problem arise. Thanks Date Time Of Last Edit: 2020-09-19 20:58:14
[2020-09-20 10:10:11] |
Make sure this setting is disabled: Chart Settings: Do Not Change Symbol Settings for Chart on Symbol Change (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) And make sure the Tick Size is set correctly in the Global Symbol Settings for both the prior and current symbol: Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
