Date/Time: Tue, 11 Feb 2025 20:26:11 +0000
Extending Line and Ray chart drawings not extending to the right.
View Count: 814
[2020-09-19 19:13:00] |
User525384 - Posts: 37 |
I have tried to draw extending lines and rays on a chart and for some reason the extension to the right does not reach/exceed the right edge of the chart. The same Extending line/ray when trying to Copy Chart Drawings From Chart #'s in another chart shows up vertically when it should be horizontal. This does not happen on every chart that is copying the chart drawing. Some charts copy it as vertical while others are copying it as horizontal. |
[2020-09-20 10:11:29] |
Increase the number of Forward Columns in the chart: Chart Settings: Number of Forward Columns (Chart >> Chart Settings >> Display >> Chart Display Items menu) Regarding the second question, refer to this section and the next one: Lines/Rays or Other Chart Drawings Move After Drawing Them: How Chart Drawings Are Mapped Between Bars with Different Starting Date-Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
