Date/Time: Mon, 25 Nov 2024 11:35:40 +0000
ACSIL: calculate at every tick
View Count: 1486
[2014-02-07 12:06:11] |
User40117 - Posts: 56 |
hello, my prev charting package had a function calculateateverytick (false/true); Is there a similar function in ACSIL ? My indicator a have ported plots bands but they only need to be updated at every bar. Now the last segment moves at every tick and this is confusing. Is it possible to avoid calculation at every tick ? ty |
[2014-02-07 15:35:41] |
ejtrader - Posts: 688 |
This code would let it calculate on end of bar only. if (sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_CLOSED) { // Perform Indicator Calculations } |
[2014-02-07 15:40:49] |
ty
[2014-02-07 18:24:43] |
Let us know if you need more help.
