Date/Time: Mon, 21 Sep 2026 06:29:41 +0000
[User Discussion] - How to get the High, Low, etc of recent buy order Bar
View Count: 1064
[2020-09-19 15:24:49]
User681150 - Posts: 62
i executed a Buy order and want to use the low of the Bar as a reference point for an initial stop
how do i access the Bars information?
i see i can use s_SCPositionData but i only see the .AveragePrice
is there another method? what are my options using ACSIL...
thanks
[2020-09-22 07:47:00]
User553714 - Posts: 184
You would need to store the entry Index of the order as a Persistent Variable when the order is first placed and then use the BaseData Array to retrieve what you need, High Low etc
ACSIL Interface Members - Variables and Arrays: sc.BaseDataIn[][] / sc.BaseData[][]
float HighPriceAtEntry = sc.BaseData[SC_HIGH][EntryIndex];
float LowPriceAtEntry = sc.BaseData[SC_LOW][EntryIndex];
