Date/Time: Tue, 11 Feb 2025 21:27:00 +0000
Quote Board High/Low Timeout Time in Seconds
View Count: 575
[2020-09-18 21:00:33] |
User117499 - Posts: 6 |
This new setting has recently been added to "General Settings"/"General 4". Appreciated! I'm running version 2170. I tested this variable set on 1,2,3,4, and 5 seconds: 1. "New Low" still times out only after 30 seconds no matter what the setting is. 2. "New High" seems to time out between 3 to 5 seconds even when I have it set to 1 seconds. I can assure you that it is not related to hardware or bandwidth. Thanks! |
[2020-09-21 22:20:22] |
We will resolve this in the next release, but there will be a minimum of five seconds to clear these highlights.
