Date/Time: Mon, 25 Nov 2024 12:55:51 +0000
Kijun of 15mn and KIJUN of 4hours on the same chart
View Count: 1408
[2014-02-07 05:31:33] |
User45578 - Posts: 49 |
Hi , May i get on the same chart and on the same region OF THE CHART ichimoku kijun of two differents Time Frame,for exemple:ON THE CHART OF 15mn ,both KINJUN 15mn AND KINJUN 4hours ? THANKS
[2014-02-07 06:03:39] |
tobi - Posts: 351 |
Have a look at the study: Study/Price Overlay Details see here: http://www.sierrachart.com/index.php?l=doc/helpdetails28.html#UsingtheStudyPriceOverlayStudy http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s118 |
[2014-02-07 21:18:07] |
The answer given in post #2 is correct.
