Date/Time: Tue, 11 Feb 2025 21:07:02 +0000
Suggestion - Anchor First Right-Click Screen
View Count: 436
[2020-09-18 16:10:41] |
User20220411 - Posts: 8 |
I use the Anchor function to set the horizontal line a lot. Is it possible to put the Anchor function on the first panel after right-clicking on the line?
[2020-09-22 11:21:20] |
The Chart Drawing Properties window is going to be redeveloped at some point. This will be looked at later on.
