Date/Time: Tue, 11 Feb 2025 18:30:56 +0000
[User Discussion] - position limits
View Count: 1035
[2020-09-18 15:52:59] |
Robert Wojczak - Posts: 147 |
How do I set a max position limit for a contract. i.e. 2 ES contracts max...... Thank you
[2020-09-18 18:57:26] |
This can be set globally or for an individual contract. Refer to: Global Symbol Settings: Instructions Global Symbol Settings: Use Global Trade Position Limit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
