Date/Time: Tue, 11 Feb 2025 18:14:26 +0000
switch from Rithmic to Denali
View Count: 547
[2020-09-18 14:27:14] |
User675180 - Posts: 10 |
Hi I have 2 Rithmic data feeds from Amp Global, one for my Jigsaw DOM and one for Sierra charts. On 1 October, I want to stop one of the Rithmic data feeds and switch over to Denali for my Sierra charts. Amp have quoted me $20 per month for Denali data feed, is the price you offer for Denali the same? |
[2020-09-18 16:34:27] |
John - SC Support - Posts: 37883 |
The Denali Exchange Data Feed costs $20.00 USD per month if you are also using the Sierra Chart Order Routing Service. Otherwise, it is $25.00 USD per month. The exchange fees are in addition to this, so depending on what exchange(s) you need, you need to add that to the overall cost. You will find all the information on the Denali Exchange Data Feed at the following link, including the exchange fees: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
