Date/Time: Mon, 25 Nov 2024 11:52:00 +0000
Custom Order
View Count: 1227
[2014-02-07 04:57:01] |
RafiH - Posts: 28 |
Is there a way to create a custom order through the trade window which starts as an OCO, but in the case of a losing stop out, automatically reverses with another OCO (could be same OCO as original but in opposite direction). In other words, the stop exit triggers a reverse position OCO (or the stop is really twice the size as the original order, but then a new OCO is attached to that order/reversed position? Does that make sense?
Date Time Of Last Edit: 2014-02-07 04:57:32
[2014-02-07 06:32:22] |
Yes we understand, but this is not supported at this time.
