Date/Time: Tue, 11 Feb 2025 18:10:56 +0000
Multiple timeframe in ASCIL
View Count: 612
[2020-09-18 09:04:25]
gfx2trade - Posts: 48
Hi team,
I am currently working on a trading system with entry triggers on a user selected timeframe (custom study added to chart).
But, I need to implement a filter to the long/short entry mechanism which depends on calculations requiring price data from a higher time frame. How can I implement it in ASCIL ? My constraint is that the user must not have to open a higher timeframe chart and make any study add/set manipulations.
Thks.
B.
Gfx.
[2020-09-18 10:21:54]
There is a requirement to have the higher timeframe chart. Otherwise, you would need to do the calculations yourself to create the higher timeframe bars within the custom study.
[2020-09-18 11:47:23]
Thks. Any hint, or example on how "to create the higher timeframe bars within the custom study.".
B;
gfx
[2020-09-18 19:06:48]
No, we do not have any code example. You just have to iterate through the base data arrays:
Working with ACSIL Arrays and Understanding Looping
And calculate the Open, High, Low, Close from the values from the shorter timeframe bars.
Date Time Of Last Edit: 2020-09-18 19:06:56
