Date/Time: Tue, 11 Feb 2025 18:21:31 +0000
Standard Account: Possible to transfer my subscription to a new pc?
View Count: 451
[2020-09-18 05:31:19] |
Riche - Posts: 20 |
Hi Sir, I had just subscribed for the standard package. I understand that a username can be used for Two pc. But if I were to buy a new pc, is it possible to transfer my subscription to the new pc? Thanks ! Regards, Riche |
[2020-09-18 09:45:59] |
There is nothing you need to do in regards to this. You just use Sierra Chart on any number of computers you want at any time. However, you can only use two computers at the same time. Specifically refer to: Sierra Chart Purchase and License Information: Licensing / Number of Systems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-18 10:18:58
