Date/Time: Tue, 11 Feb 2025 18:35:15 +0000
Stop order not getting activated
View Count: 531
[2020-09-18 00:37:19] |
vish100 - Posts: 111 |
In my SIM account with FDXM (mini DAX), stop buy orders are not getting activated. I have tried via trade window and also via chart trading. The sell stop orders are working fine. The strange thing is whenever I try to create a buy stop order the DPL (Daily profit loss) keeps going up. Seems like there are some hidden orders in the background that are not getting cancelled even tho I have pressed 'Cancel All' many times. Can't see anything in logs either. Could you please help? thx Date Time Of Last Edit: 2020-09-18 00:37:49
[2020-09-18 05:14:24] |
When you make reference to a simulated account, are you referring to Trade Simulation Mode?: Trade Simulation You should have definitely no trouble with orders or canceling them in Trade Simulation Mode. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-18 05:14:57
[2020-09-18 06:13:13] |
Yes 'Trade simulation mode'
[2020-09-18 10:12:16] |
Make sure you are not using a Stop-Limit order. And instead a simple Stop order: Order Types: Stop And refer to: Trade Simulation: How Orders are Filled Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-18 10:12:49
