Date/Time: Tue, 11 Feb 2025 18:40:45 +0000
bid and ask difference bars fix ?
View Count: 574
[2020-09-17 22:45:35]
zippyzip - Posts: 293
i have seen a few threads on this and seen that it was other data causeing the issue but i have denali data and still have same issue with the bid and ask deifference volume bars .
please advise a fix , thanks
Private File
[2020-09-18 05:11:31]
What you see is correct. If you are referring to the opening value, that is not known. How that is set is explained here:
Ask/Bid Volume Difference Bars
[2020-09-18 11:42:08]
that makes no sense cause u have overlapping volume crossing the zero line , this is what they look like normally so u can clearly see something is wrong
Private File
