Date/Time: Tue, 11 Feb 2025 18:16:26 +0000
Shortcut for buy/sell at cursor price
View Count: 1130
[2020-09-17 17:00:47] |
User158665 - Posts: 44 |
We can move attached Targets/Stops to price with Keyboard shortcut, but I cant find how to limit buy/sell at cursor price. I have only found the "offset from reference price". Do you have this option or plan to add it? |
[2020-09-18 10:20:07] |
Have a look at the Chart DOM: Chart Trading and the Chart DOM: Using the Chart DOM / Order Entry Ladder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
