Date/Time: Tue, 11 Feb 2025 21:33:40 +0000
leeloo rithmic
View Count: 921
[2020-09-17 16:09:18] |
User765845 - Posts: 1 |
Hello i have a leeloo rithmic account and i can't connect with the stream, i followed the plan to connect with the download from the bridge but it still won't connect
[2020-09-17 17:32:36] |
We do not provide support for Rithmic. And additionally, you need to have a direct account for that connection: Direct Sierra Chart Account When you are using Sierra Chart that has been provided through an affiliate, you do not have a direct paid account with us, and you wish to access functionality that is not provided in your limited version, you must have an account with Sierra Chart directly and have a standard installation of Sierra Chart. To accomplish this, follow the instructions below: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-21 16:53:57] |
User267701 - Posts: 66 |
Can you link an overview about features ONLY direct SC clients have access to?
[2020-09-22 10:47:26] |
There is nothing specifically written but basically you can only connect to external Trading services directly associated with the broker.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-22 10:47:35
