Date/Time: Tue, 11 Feb 2025 18:42:48 +0000
Sierra is stoping
View Count: 567
[2020-09-17 15:12:08] |
User491428 - Posts: 87 |
Sierra is now stopping , its not work. i have reset and the datas are new loading. the version is the newest! |
[2020-09-17 16:09:04] |
What do you mean by Sierra is stopping? This is not clear for us. Are you still having a problem? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-17 17:15:10] |
Today it was 11 clock, sierra does not plot data in my chart and in my dom
[2020-09-17 17:27:43] |
When you have a problem, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Also make sure this option is enabled: Data/Trade Service Settings: Reconnect on Failure (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-17 17:31:04
