Date/Time: Tue, 11 Feb 2025 18:14:25 +0000
No space for drawings to the right
View Count: 496
[2020-09-17 11:41:10] |
User97684 - Posts: 136 |
Hi, Pls help - why one chart has tonnes of space to the right , and the other doesnt ? Many thanks |
Attachment Deleted. ![]() ![]() |
[2020-09-17 12:59:55] |
User907968 - Posts: 826 |
They look different because the chart bar spacing is different between the charts, but in terms of forward columns, they are probably the same. Have a look at this: Chart Settings: Number of Forward Columns (Chart >> Chart Settings >> Display >> Chart Display Items menu) |
[2020-09-18 10:13:58] |
Yes check the setting given in post #2.
