Date/Time: Tue, 11 Feb 2025 18:17:33 +0000
"Add symbol alert" is not showing up on right click in the chart
View Count: 462
[2020-09-17 07:30:13] |
SatG - Posts: 23 |
Hello, "Add symbol alert" is not showing up on right click in the chart. Could you please advice how to enable this again ? Regards, Sat |
[2020-09-17 15:05:04] |
John - SC Support - Posts: 37883 |
Customize chart shortcut menu: Global Settings >> Customize Chart Shortcut Menu and add the Add Symbol Alert item. Refer to the information here: Global Settings Menu: Customize Chart Shortcut Menu (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
