Date/Time: Tue, 26 Nov 2024 12:33:38 +0000
RULER AVAILABLE????????
View Count: 1526
[2020-09-16 19:45:23] |
WillieT - Posts: 1 |
Hello, Is there a tool that allows the user to click on a current bar and then drag it backwards to get a bar count? Even the most simple of platforms have it. Please advise. Thanks |
[2020-09-17 02:31:52] |
Yes you can do this with the Chart Calculator drawing tool: Chart Drawing Tools: Chart Calculator Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-28 21:17:00] |
Jason Almeida - Posts: 2 |
Is it possible to have a small dot or small box at the ends of the ruler tool in-order to more easily reference what tick the tool is starting and stopping on?
[2023-11-30 15:32:40] |
John - SC Support - Posts: 36286 |
There is not an option for this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
