Date/Time: Mon, 25 Nov 2024 11:33:58 +0000
Draw Lines Forward
View Count: 1315
[2014-02-06 17:28:11] |
crazybears - Posts: 314 |
Hi SC Support can i draw indicators , on main subgraph starting at SC.Index+x , with X>=1. if yes how much can X be ? thanks |
[2014-02-06 18:02:34] |
Yes. Refer to the documentation here: https://www.sierrachart.com/index.php?l=doc/doc_DLLTools.html The setting which affects this is Chart >> Chart Settings >> Advanced Settings >> Number of Forward Columns. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
