Date/Time: Tue, 11 Feb 2025 18:07:27 +0000
freeze windows in chartbook
View Count: 476
[2020-09-16 11:29:18] |
User884550 - Posts: 149 |
is it possible to somehow fixate/freeze windows in the chartbook, so when I open chartbook on another PC with different display resolution, windows would be of same size relative to display? otherwise, given the fact that transferring drawings between chartbooks is not possible, i have to spend quiet some time readjusting everything after copying chartbook to higher res workstation
[2020-09-16 14:23:04] |
John - SC Support - Posts: 37883 |
There is no way to do what you are asking in terms of keeping a window the same size relative to the monitor resolution. But, you can copy drawings between chartbooks. Refer to the information in the 4th paragraph here: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
