Date/Time: Tue, 11 Feb 2025 17:59:47 +0000
Rollover adjustment help please.
View Count: 444
[2020-09-16 11:09:33] |
User731023 - Posts: 140 |
Hi, I need to lower September by .75. Can not get it to work for some reason. Can you see the problem? Thanks, Date Time Of Last Edit: 2020-09-16 11:14:15
[2020-09-18 10:24:18] |
You need to enable this option: Global Symbol Settings: Use Custom Symbol Settings Values (Global Settings >> Symbol Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
